Z06 Front conversion part numbers
Old Jan 8, 2008 | 11:33 AM
Rogue C6's Avatar
Rogue C6
Default Z06 Front conversion part numbers
Hi All,
I am looking for the part numbers for the upper grill in the nose and the front left and right side vent inserts.
I have the other part numbers and only need the ones listed above.
I have emailed gmpartswarehouse and parts@Fichtner and have not heard back from them yet.
Thanks In Advance!
Patrick
Old Jan 8, 2008 | 04:34 PM
Charley Hoyt's Avatar
Charley Hoyt
1) Front facia air scoop molding (upper air inlet in bumper) - 15801407
2) Right front fender side scoop molding (inner and outer) - 15807844 / 15787683
3) Left front fender side scoop molding (inner and outer) - 15807845 / 15787684
Charley
Old Jan 8, 2008 | 05:15 PM
Rogue C6's Avatar
Rogue C6
Charley
Thanks Charley! You Da Man!!!
Old Jan 8, 2008 | 08:09 PM
Charley Hoyt
I'm happy to help. I am looking forward to seeing the final results.
Charley
Old Jan 21, 2008 | 03:38 PM
427mustang's Avatar
427mustang
Charley
I believe the part numbers ending in 7683 and 7684 are for the rear quarter scoops.
The correct numbers for the front inners are 15895240 and 15895241.
Hope this helps someone in the future.
Old Jan 21, 2008 | 06:14 PM
Rogue C6's Avatar
Rogue C6
oh no... did I order the wrong parts?
Part Number: 15895240
Fender - Exterior trim - Ornament - Inner Inner Right - W/z06 2006 - 2008
Part Number: 15895241
Fender - Exterior trim - Ornament - Inner Inner Left - W/z06 2006 - 2008
Part Number: 25790357
Quarter panel - Exterior trim - Scoop - Outer W/z06 Left 2006 - 2008
Part number 15787683 was superceded by part number 25790357.
Part Number: 25790358
Quarter panel - Exterior trim - Scoop - Outer W/z06 Right 2006 - 2008
Part number 15787684 was superceded by part number 25790358.
Part Number: 15807844
Fender - Exterior trim - Ornament - Outer Outer Right - W/z06 2006 - 2008
Part Number: 15807845
Fender - Exterior trim - Ornament - Outer Outer Left - W/z06 2006 - 2008
Old Jan 21, 2008 | 08:23 PM
Charley Hoyt
Sorry for the mis-information. I confirmed my numbers with the parts list in the Vette Magazine article ( I guess we were both wrong). Let me know if you end up being out any cost because of my mistake...I will be happey to send you a check for the loss...That's the least I can do for steering you wrong.
Old Jan 21, 2008 | 09:24 PM
Rogue C6's Avatar
Rogue C6
No, no, not at all. No big deal. I just want to make sure I have the right parts. There is always someone doing a wide body, so the parts will not go to waste.
Thanks again!
Thanks 427Mustang!
Patrick
To Z06 Front conversion part numbers
