tilt column
Old Jan 10, 2008 | 02:50 AM
VETTAMOUS's Avatar
VETTAMOUS
St. Jude Donor '11-'12, '14
Default tilt column
in the older cars the tilt would get slack and loose if you used them to much. its always on my mind to not use tilt as much as possible to keep this from happening. anybody have their tilt go bad?
Old Jan 10, 2008 | 02:58 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
I don't recall that ever being a problem posted about here.
Old Jan 10, 2008 | 03:00 AM
VETTAMOUS's Avatar
VETTAMOUS
cant believe i came up with something new
Old Jan 10, 2008 | 06:42 AM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Tilt has come a long way since the 70's and even if it broke your worrying about it is making you enjoy your car less. Use it, enjoy it, if it breaks it can be fixed.
Old Jan 10, 2008 | 06:51 AM
VET4LES's Avatar
VET4LES
I had a 65 Pontiac that had a problem but none since.
Old Jan 10, 2008 | 08:00 AM
StanNH's Avatar
StanNH
This is a non-issue. I've had manual tilt adjustments on other cars too, including Audis, and this has never been a problem I've had, seen, or even heard of.
If you apply this same logic to other things in your car that move, you should be afraid to use yor windows, seat adjustments, glove box door, hood release, hand brake, rear view mirror, ... I could go on.
This is not something you should worry about.
Old Jan 10, 2008 | 09:31 AM
Ozone's Avatar
Ozone
I agree that using the tilt won't harm the steering column...BUT there have been numerous posts here about the telescoping function causing a connector to come loose, thus causing a "Service Active Handling" code.
Old Jan 10, 2008 | 09:37 AM
VetteManRay's Avatar
VetteManRay
From: Forest Hill, (Out in the country), north of Baltimore. Maryland. Land of "Pleasant Living" with my Corvette, steamed crabs & crab cakes.
Default A Big “HELLO” from Forest Hill, Maryland.
No problems with mine.
Old Jan 10, 2008 | 09:58 AM
johnodrake's Avatar
johnodrake
Moderator
Old Jan 10, 2008 | 11:26 AM
BigJoe's Avatar
BigJoe
I set mine once and never moved it after that. Unless you have multiple drivers why would you ever need to readjust it?
Old Jan 10, 2008 | 11:30 AM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
I use mine every time I get in the car. I like the wheel down pretty low, and it's tough to get out of the car with the wheel down, so I release it to full "up" position.
Only drawback to the wheel position I prefer is that I can't read the speedo very well, becaue the wheel's in the way.
I don't have the telescopic function, which is the only option I wish I had on the car.
Old Jan 18, 2008 | 06:48 PM
VETTAMOUS's Avatar
VETTAMOUS
i try not to touch the steering wheel in the same place all the time to keep leather fresh. i dont really worry just carefull!!!
Old Jan 18, 2008 | 07:43 PM
Vette_DD's Avatar
Vette_DD
One position for driving (down) and one position for getting into/out of the car (up).
Old Jan 18, 2008 | 07:52 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Using the tilt often in the C5 did cause the wiring for the headlight switch to break. This caused the headlights not to come on sometimes. The wire harness to the switch run up through the steering column and was flexed each time the tilt was used.
I've not heard of this problem in the C6.
Tom
To tilt column
