Cruise Control
Old Jan 10, 2008 | 09:02 AM
bigdogk9's Avatar
bigdogk9
Default Cruise Control
Anyone else ever have this issue with their C6 A6. I've got less than 5000 miles and I went to us the cruise and it wouldn't engage. I looked at the fuse box , as well as, in the book for the fuse and it wasn't listed. Does anyone have any ideas?
It was working just fine a few days ago.
Old Jan 10, 2008 | 09:13 AM
VetteManRay's Avatar
VetteManRay
From: Forest Hill, (Out in the country), north of Baltimore. Maryland. Land of "Pleasant Living" with my Corvette, steamed crabs & crab cakes.
Default A Big “HELLO” from Forest Hill, Maryland
Gee, I'll try to use mine too.
Old Jan 10, 2008 | 09:20 AM
User 020720's Avatar
User 020720
Mine worked fine the one time I used it, how about take your under warranty car to the dealer?
Old Jan 10, 2008 | 09:24 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Try using your foot and making sure that the brake pedel is all the way up. A little down and cruise will not work.
bigdogk9's Avatar
bigdogk9
Taking to the dealer would be my next option, however, you know how they are and would want to keep it for a day.
Old Jan 10, 2008 | 09:58 AM
alanancy's Avatar
alanancy
No problems here!
Old Jan 10, 2008 | 10:03 AM
Vette_DD's Avatar
Vette_DD
Mine went out about 4 or 5 months ago. Although the fuse seemed to be good, I got the service dept. at my local dealer to give me another one. That still didn't fix it.
When I took it to the dealer, he had to replace the BCM, under warranty. That fixed it - no problems since.
Old Jan 10, 2008 | 10:33 AM
RadarP3C's Avatar
RadarP3C
Does your A6 go into 1st gear when this happens? The reason I'm asking is, I've had problems with my transmission. Whenever it won't shift into 1st gear, I've lost the ability to engage cruise control. Dealer says transmission problem is causing the cruise control problem. Today the car is at the dealer for the 3rd "fix." My next option maybe the lemon law........
Old Jan 13, 2008 | 08:54 PM
bigdogk9's Avatar
bigdogk9
I was able to get into 1st gear.
Yesterday while out driving I decided to try the cruise again and much to my amazement it worked. I have no idea why it didn't work for several days but it works now. Must of been some electrical fluke.
Old Mar 2, 2008 | 07:58 PM
newgene's Avatar
newgene
Just FYI, I know the C5 has a dedicated switch on the clutch pedal at the top that must be depressed for cruise to work. This is not the switch on the firewall, but under the kick panel. The problem usually rears its head when a master cylinder has been changes, or if you've done some work under the panel.
Again, I'm not sure if they did away with it on the C6, but my C5 has it, and I had to adjust it to get the cc to work. Unless you get it adjusted right, it could be intermittent as well. Just my $0.02.
Old Mar 3, 2008 | 04:24 AM
foremaw's Avatar
foremaw
St. Jude Donor '08-'09-'10-'11-'12
The Cruise Control fuse is in the passenger side footwell fuse box. See page 422 of your Owners Manual, its listed in the column on the right. It has its own fuse.
Old Mar 3, 2008 | 06:28 AM
havesleep's Avatar
havesleep
This happened to my 2007. Take it to your dealer, there is a connection in the colum and they sometimes become disconnected.
To Cruise Control
