I've noticed that at night with the headlights on I don't have the back lighting of radio/hvac and the pod on the right side of the gauge cluster controls. Everything works but at night I can't see anything. The radio face and the hvac face light up. I looked in the owners manual and the only fuse I found was the cluster/hud one in the footwell.
Anyone else have this problem? Is there a different fuse I should be looking for.
Thanks for any help
Kelly
Mods could you please move this to C6 Tech
Reason: In wrong section. Mods please move to C6 Tech. Thanks
Try turning the dimmer switch located down and to the left of the steering wheel...
That's my first thought as well. Not sure if this is your problem or not but brightness levels are remembered as part of the fob memory and driver personalization settings. Have you changed fobs lately?
