Chime level adjustment question
Old Jan 11, 2008 | 11:30 AM
JROCK747's Avatar
JROCK747
Default Chime level adjustment question
Quick question.....How do you adjust it if you have the Nav system ?
Chime Level Adjustment
The radio is used to adjust the vehicle’s chime level.
To change the volume level of the chime, press and hold
pushbutton 6 with the ignition on and the radio power
off. The volume level will change from the normal
level to loud, and LOUD will appear on the radio display.
To change back to the default or normal setting,
press and hold pushbutton 6 again. The volume level
will change from the loud level to normal, and NORMAL
will appear on the radio display. Only one chime will
be heard when changing from the normal to the
loud setting. Each time the chime volume is changed,
three chimes will sound as an example of the new
volume selected. Removing the radio and not replacing
it with a factory radio or chime module will disable
vehicle chimes.
Old Jan 11, 2008 | 11:37 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Really sorry, but I must not have had enough coffee yet this morning. If I'm remembering correctly, there is no button 6 on a Nav equipped car with the radio off. Radio on there is of course...will mess around with it in a short while and see what I can find out.
Old Jan 11, 2008 | 11:41 AM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
The chime has two levels, loud and louder.
Old Jan 11, 2008 | 11:45 AM
JROCK747's Avatar
JROCK747
thanks
To Chime level adjustment question
