Checking clutch fluid.
Old Jan 12, 2008 | 08:01 PM
JLargo's Avatar
JLargo
Default Checking clutch fluid.
Should clutch fluid be checked when the car is hot or cold? Does it matter?
Old Jan 12, 2008 | 08:07 PM
johnodrake's Avatar
johnodrake
Moderator
I don't know that it matters - but I check mine cold and it is cold when I to the 'Ranger Replacement'
Old Jan 12, 2008 | 08:21 PM
Leo the Lion's Avatar
Leo the Lion
Cruise-In II Veteran
Same here, always been cold when I change it via the "Ranger method"
Old Jan 12, 2008 | 08:46 PM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Brake / chutch fluid is not subject to thermal expansion. It wouldn't perform well at it's job if it were. So, yes, it should be ok to check it either warm or cold.
To Checking clutch fluid.
