Sorry guys, I have an ignorant question about new car prep.
My new coupe is being produced next week. I could not take museum delivery for scheduling reasons. I have read on here about how wonderful they prep your car at the museum vs. what the dealership might do when the car comes in.
So I guess my question is: what kind of prep/protection is on the paint when it comes to the dealer? I kinda don't want my dealer to touch it or clean it up when I pick it up due to some issues I've read about here. ( swirls, scratches, and general carelessness.) I live in Indy and won't be able to really get a good coat of polish/wax on it for a couple months. Is it protected enough to now not do any damage or the like until spring?? Is it smart to not have the dealer clean it/wax it when it comes in?? I might just be being paranoid, but screw it, this is my baby. Opinions please??
Don't let dealer touch it with their dirty soap and water. Your paint will hold up fine without wax for the short term, so I wouldn't worry too much about it.
The Vettes get adhesive plastic sheets applied to the larger flat surfaces that don't get removed until the PDI is performed at the dealership.
As far as leaving it unwaxed, there's too many unknown variables to make a good recomendation. How clean will it stay, will it be driven until spring, exposed to weather or road salt?
Yes, the car will be driven. NOT in snow or anything, but there will be times I will take it out and there will probably be some salt still lingering on the roads, BUT it will stay clean with a high powered spray wash and undercarrige wash until I can start washing and polishing outside.
Also, keep in mind that some new cars sit out on the lot for six months or even longer without being waxed. Basecoat/clearcoat is a very durable surface. Paint is ten times better than it was 25 years ago. Also, it is recommended that you not wax it for a few months anyway. Wax can be a barrier that could prevent all of the reducers from releasing during the paint curing process. Yes, I know that some will say that the paint is baked on, and they are right, but there is still no substitute for time as far as the curing process goes. I could go on for hours on this subject, but I won't bore you.
Very good point about the cars sitting on lots for a while. Really hadn't taken that into account. My 04z06 I have now is machine silver and won't really show any swirls or imperfections, but the new one is going to be black and want to take care of it as best as possible without being behind the 8-ball right out of the gate!!
Oh, and you can't bore me on this subject, I want to know as much as I can
Swirls are going to happen, no matter what you do. They key is knowing how to stay on top of it. You will eventually get "rub" marks on your black C6 that won't come out by simply hand rubbing it. This is where a buffer comes in, and sometimes it would even need to be buffed with compound, then buffed with glaze with a softer foam pad. As a rule, if a "scratch" cannot be felt with your fingernail, then it can be buffed out without sanding. If it can be felt, but, just barely, then light sanding and buffing usually can fix it. I know that you have no intentions on scratching it......most likely you will need only to worry about swirls, but I'm just giving you some examples of how forgiving this paint really is. If you want a "free" tutorial, you can send me a private message with a phone number and best time to call, and I will give you the low down on whatever this warped mind of mine has to offer. On that note, I'm going to bed.
Steve
You've already heard it so I'll just pile on my .02. Especially with a black car, you will be much happier if you instruct your dealer to not wash it during the PDI. Unless the dealer is unique in their care, they can't help but put swirls in the finish. Good luck and early Congrats!
I made it a point to tell the dealer it was ok to wash the car, but no waxing! But, I only did this after I took a tour of the service department, had them show me what they use for washing and also talked to the guy who was going to prep my car. They did an awesome job and the car was perfect when I picked it up. Get to know your dealer and the people who work there, it will pay off in the end. Go Colts!
Mine was not washed untill I got it home and did it myself.
I do not trust the lot boys to wash my car. It has always been dried with a leaf blower to help prevent swirls. With black it is even more imprtant. The less contact, the better.
