window question
Old Jan 20, 2008 | 06:20 PM
Sonic1's Avatar
Sonic1
Default window question
Not sure if this is the right place but here goes. Went out to drive the vette this morning and the windows go down slightly when I open the door but don't go back up as they did in the past. I tried on both doors and same outcome. Is it because they are cold or are they broken? First problem I've had. Thanks for any help.
Old Jan 20, 2008 | 06:21 PM
no$4vette's Avatar
no$4vette
in the owners manual it tells you how to reset the indexing. its really easy.
Old Jan 20, 2008 | 06:27 PM
Sonic1's Avatar
Sonic1
Awesome, thanks!
Old Jan 20, 2008 | 07:53 PM
Vette_DD's Avatar
Vette_DD
If it's above freezing where you were this morning, then it's not the cold, but as indicated above, the window indexing needs to be reset. A good reason to fill out your profile so we know more about you and your car. Here is the set of instructions needed .
Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual.
Old Jan 20, 2008 | 08:49 PM
Sonic1's Avatar
Sonic1
I live in FL and normally park my car in the garage but am TDY to AL, had to park outside in the parking lot, and yes it was below freezing last night. Profile updated, thanks for the tip. Thanks also for the info, it did the trick and the windows are reset.
Old Jan 21, 2008 | 12:24 AM
dkrhardy's Avatar
dkrhardy
TDY to AL? Maxwell for a school? I'm in Montgomery!
Old Jan 21, 2008 | 11:00 PM
Sonic1's Avatar
Sonic1
Yep, TDY for SNCOA at Gunter.
Old Feb 3, 2009 | 11:38 PM
Payton 63' and 06''s Avatar
Payton 63' and 06'
From: Surgeon General never said anything about smokin' tires! Pigeon Forge, Tn.
Default Great info on freezing windows.
Thanks for the easy fix to restting the window indexing. I have taken my 06 coupe in twice in the last month for them to fix this (under warranty). But they failed to mention that there is such a simple fix. Great thread!!!
Old Feb 4, 2009 | 12:04 AM
Onyasix's Avatar
Onyasix
Yep, they want you to keep coming back so they can collect that warranty money from GM.
To window question
