I know I've seen a thread on this, did a search and didn't find what I'm looking for.
What upgrades were done to the '08 auto transmission?
The reason I ask is because I’ve had my ’07 auto transmission in the shop for problems downshifting (lack of) into 1st. Three fixes: 1) replaced solenoid, 2) replaced valve body and 3) add valve body spacer plate.
After the spacer plate addition, the paddle shifts seem quicker and firmer. Just wondering if a spacer plate was one of the ’08 upgrades?
Thanks.
The '08 has tighter shifts...less lag from one gear to the next. How was that done? Sorry, I do not know that, but I do know that it is a nice improvement. My guess would be changes in the valve body.
Still the same trans...software tunning helped a lot though. Shifts are indeed tighter but in a good way. Much more seamless transitioning through the gears. In paddle shift mode, the engine now rev matches when you downshift. For example keeping your foot on the gas going a steady 50mph in 5th down shift into 4-3 and there is no bog because the engine revs are matched to the speed of the wheels spinning...
I didn't know the 08's rev matched. Is that confirmed ?
Absolutely confirmed -- I did not know that the previous years did not do this.....That's one of things that made me smile the widest when I was test driving my '08...that rev matching is just
Yes, I agree it's confirmed, rev matching is great. Sounds good,too.
I agree this makes it a much more complete trans, match down revs, I can stand on the brakes and hit the paddles, as I search for the apex, not upsetting the car with downshifts that are not matched
Are you saying that if you are driving in 3rd gear at 3500 rpm and paddle down to 2cd gear (no foot on the brakes, please) which would bring the revs up to say 4500 rpm....that its a totally smooth and seamless shift? Unlike my 07 where you would feel a jerk and lurch from doing that?
Yup! That's exactly what he's saying. The rev matching is better than any human can do it, because it's perfect every time. It sounds great with the NPP open with the M2W switch too!
BTW you can put your foot on the brakes at the same time. It's a great way to set up for accelerating out of a tight, slow corner!
Say, one more question. On the '07 A6 I have, with the shift lag, on the racing course, I need to paddle shift at around 5800 or so to time it for the lag to actually make the shift around the 6500 redline mark.
So I heard for the '08 that the lag is improved. So do tell, where are you all paddle shifting at so it actually makes the shift at the redline?
Well! My problem is that you don't know where it will shift. I took it up to 5000 rpm and paddleup. Well, it started to pop and sounded like it was over reved. What's up with that?
