Not sure on this specific part, but it's possible that this is such a generic part that it may not have a specific GM part number, like a lug nut, or a valve stem cap.
You might ask for the trim panel retainer by name and see if they don't keep them in a general bulk parts supply. These are a typical type fastener used across the entire line of GM vehicles.
Does anyone know the part# for the inner white door panel pushpins?
As I removed the panel a couple broke.
Thanks a lot!
I did the same thing this morning... getting the door panels off is pretty easy, but I'm struggling to get them back on. There are at least two excellent posts on the CF that describe this process, but I'm still having a hard time getting the top row of panel clips to "grab" the steel door frame correctly... any tips from others experience would certainly be appreciated!
I'll try to finish this tomorrow evening after I stop at the Dealer for the replacement nylon threaded pins.
If you don't get a part number before then, I'll get one from the Dealer tomorrow and broadcast it!
