C6 Headlight Exchange
Old Jan 27, 2008 | 08:00 PM
sam_b's Avatar
sam_b
Default C6 Headlight Exchange
Does anyone have pictures and/or the procedure to swap out the C6 headlights? I got some black ones but don't want to tear into it until I have an idea. Thanks.
I did a search but could find anything.
Old Jan 27, 2008 | 08:14 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You need to loosen the front fenders. Removal would be easier but not necessary. The headlight has a gasket that seals to the fender opening. Once the fender is out of the way removal is fairly straightforward. I'll post up a few pictures for you.
Old Jan 27, 2008 | 08:55 PM
sam_b's Avatar
sam_b
Default Thanks
[QUOTE=talon90;1563829147]You need to loosen the front fenders. Removal would be easier but not necessary. The headlight has a gasket that seals to the fender opening. Once the fender is out of the way removal is fairly straightforward. I'll post up a few pictures for you.
Thanks!!
Old Jan 28, 2008 | 06:01 AM
talon90's Avatar
talon90
NCM Ambassador
Just one more bit of information as far as accessing the three mounting screws for the headlamp assembly. I tried to post it last night but photobucket.com was acting up. You will need to remove the wheel liner to get at the headlamp from the bottom.
Old Jan 28, 2008 | 06:33 AM
JFijolek's Avatar
JFijolek
Very impressive engineering At least you dont have to remove the engine
Old Jan 28, 2008 | 07:47 AM
talon90's Avatar
talon90
NCM Ambassador
They weren't designed to be swapped out. The HID should last well beyond most owners retention. The bulbs that need to be replaced. can be accessed with a panel in the wheel well....5 minute job.
Old Jan 28, 2008 | 09:16 AM
PolishDude's Avatar
PolishDude
i liked the headlights on the 99-04 mustangs, those were designed great. You could literally pull it out in about 30 seconds, if anyone had one of those cars they know what im talking about, probably one of the best engineered headlight removal systems ive ever seen....if you need to take it out a lot that is
Old Jan 28, 2008 | 10:19 AM
sam_b's Avatar
sam_b
Default Nice
Great drawing, thanks.
Old May 10, 2008 | 04:11 PM
Axl Jack's Avatar
Axl Jack
Bringing back an old thread but.... you could have a small rock chip one and you'd want to replace it. Unfortunately, I'm in this particular situation. I'm just going to wait until it worsens, then replace it.
Old May 10, 2008 | 04:18 PM
dvandentop's Avatar
dvandentop
i am doing the swap when my passenger black one comes in how it go for your swap original poster?
Old May 10, 2008 | 04:33 PM
talon90's Avatar
talon90
NCM Ambassador
I understand that. It really isn't all that hard to change. The rock chip while unfortunate, is not really that common. I was responding to the other poster who somehow left me with the impression that they would have preferred quick disconnects from the fender.
Old May 10, 2008 | 05:09 PM
Salt's Avatar
Salt
Great question Sam b, where did you order or get the black Light assembly? How much were they? if you don't mind me asking. Please post pic's when done.
Talon, You're the man, thanks also for the detailed description and diagram, it's people like yourself that makes this Forum rock, Salt
Old May 10, 2008 | 05:14 PM
dvandentop's Avatar
dvandentop
i will post pics of mine when done this week hopefully!
Old May 10, 2008 | 07:39 PM
TrackNoob's Avatar
TrackNoob
Boxster was a cartridge for the entire headlamp/turnsignal assy (bulbs, housing, cover, everything).
One quarter turn on a "bail" on the the inside of the trunk, and poof, it slides out on a track into your waiting hands.
15 seconds, start to finish, with a beer break in the middle.
To C6 Headlight Exchange
