put in REVERSE?
Old Jan 28, 2008 | 03:24 AM
ChRpin VETT's Avatar
ChRpin VETT
Default put in REVERSE?
Do i have to put my 06 vette in reverse when I park and turn it off to reduce battery power loss?
My battery was replaced for free by warranty . I asked why my battery died so early they said it was because I didnt put it in reverse.
I thought this issue was resolved for the 06
Old Jan 28, 2008 | 03:36 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
No, you do not have to park it in Reverse (but GM recommends it). That particular battery drain issue was for the 2005 model year only. Your battery drained/died for some other reason.
Old Jan 28, 2008 | 03:37 AM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Not needed to park in reverse on 06 and up C6's and C6Z's.
Only 05's......
Ben
Old Jan 28, 2008 | 03:41 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Your thought is correct. The diagnosis you got was in error.
Old Jan 28, 2008 | 04:17 AM
User 020720's Avatar
User 020720
My dealer told me the same thing when I bought my new 07 MN6, that I had to shutdown in reverse or it would drain the battery.
That was the last time I asked my selling dealer anything about this car.
Old Jan 28, 2008 | 06:56 AM
VET4LES's Avatar
VET4LES
Only 05's......
Ben
Old Jan 28, 2008 | 07:40 AM
loubob57's Avatar
loubob57
Had my 07 for 9 months now. I have never put it in reverse at shut down. Battery is doing fine.
Old Jan 28, 2008 | 08:20 AM
vetdude's Avatar
vetdude
There is a TSP however that was issued for revising the software for the electronic doors which addresses battery drain for the '06 and newer cars. Do a search using TSP as the keyword.
Old Jan 28, 2008 | 09:48 AM
no1fltim's Avatar
no1fltim
That is the exact problem with dealerships - very few Vette trained technicians. I was told the same thing about my 08. Not a fault of the people at the dealership - they have to be able to work on many different models. There just isn't time to stay up on every change in every model. How many Vettes come in for service vs other models? CF is the best place to find a good technician in your area.
Old Jan 28, 2008 | 09:54 AM
Paul Scarpelli's Avatar
Paul Scarpelli
There is a technical service bulletin on the '05s that keeps the battery from drawing down all the way if you accidentally get NEAR reverse, but not actually INTO reverse. I had dead battery syndrome five or six times, and I haven't had it since the reflash.
Oh, and your dealer is misinformed. Dealers still tell C5 and C6 owners they have to have the doors closed when the car goes up on a lift or the frame will bend...and that's a C4 old wive's tale.
To put in REVERSE?
