Battery Issue
But if I find that I won't be driving the car for an extended period of time I plug in the ctek 3300 charger to be safe.
Your weather (more temperate, less juice-robbing cold) and the fact that you will drive it almost every day, are a help.
I think for $20 +/-, however, having a battery tender and using it occasionally can't hurt. And they are available at just about every car parts store.
That's my understanding of the "battery issue."
The posts the OP is referring to relate to the 2005-2006 m.y. C6's. In 2005, the MN6 cars were released with a software problem - you had to leave the cars in reverse when shutting down in order to command the computers to shutdown. Lots of people didn't do that, so the computers kept running, causing a battery kill. GM issued a reflash for that, and later 2006 cars onward did not need this procedure. The issue was resolved.
A second issue also cropped up some 2005-06 cars (MN6) and 2006 cars (A6) that also caused the computers to continue to run, even after shutdown. Personally, I went through 3 batteries under warranty until GM issued a reflash in 12/06 to address this issue. I have had no problems since, and I've heard of no reports of DBS (dead battery syndrome) hitting 2007-2008 cars.
The fact is, however, that some systems are always running on the car - the sensors for the FOB, for example. OnStar is always active as well. This drains power, and if the car is left for too long without recharging the battery, the car won't start. It's that simple.
As a DD, you may be alright, but frequent short trips cause a problem because the car doesn't run long enough to recharge the battery. Make sure the car is run long enough (20 minutes or so) to do that. If it is going to sit - plug it in. Wally World sells a $15 charger that works great (I use it).
My battery is totally drained if the car sits for 7 days. I've had that happen twice in January and last night I went out and bought a trickle charger. For the amount of money the vehicle costs, I would think it would be able to sit without starting it for 7 days before the battery dies.
BTW, when I put the trickle charger on the battery, it sounds like relay is clicking on and off. I found the relay and had to remove it from the fuse box.
All accessories are turned off before I shut down the motor.
Chuck
Other issues that may have drained batteries in 2005 and later vehicles included OnStar links, rolling garage door opener codes, fob placement, and RF interference from external sources. It took GM quite a while to figure it all out, but they eventually did and have apparently corrected most, if not all, of the issues.
Now, all we have to worry about is the capability of the Delco OEM batteries in dealing with the normal electrical background drain that is inherent in the C6. The factory claims a fresh battery should go 30 days before it drains. With a new battery, and in warm weather, this is probably true. In cold weather, and a less than new battery, this can vary quite a bit.
Hope this helps clarify the issue.
http://forums.corvetteforum.com/show....php?t=1719717
