different run flats?
Old Feb 1, 2008 | 09:03 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default different run flats?
I have been told that there is a difference between standard--
Goodyear Eagle F1 Supercar Extended Mobility Technology Tires, and the same but from a Z51 C6?
Old Feb 1, 2008 | 10:44 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That is correct. The tread pattern is visibly different, and the Z51 tires are (surprisingly) non-directional, you can flip wheels L side to R side without remounting the tires (your TP sensors will be reversed without a reset). But the Z51 tires have a "this side in" asymetric tread while the base tires are symetrical inside-to-outside.
Then there's the all-season runflat, looks just like the base tire but has a rubber compound designed to have better traction at low temps. Limited to 168 mph, if that's an issue for you.
Old Feb 2, 2008 | 07:33 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Thanks..Considering some C6 run-flats (take-offs) for my C5, but am tired of the "Run Flat" road noise, and was told the "Z51" runflats are going to be quieter?
So how do I tell the difference between these C6 RF's? (does it actually say this side in?)
Old Feb 2, 2008 | 10:35 AM
haljensen's Avatar
haljensen
The Z51 runflats state "Supercar" on the sidewall.
To different run flats?
