I tried to remove the front emblem from my 08 c6 the way you guys said. i got out the hair dryer, poured some "goo Gone" on it to soften up the adhesive, and after 30 minutes all i managed to do was to break a whole container of Dental Floss and loose all the feeling in my fingers. Is the another way to cut thru the adhesive or did i just use cheap Dental Floss? thanks jared
I thought this solution or method was for the side GM logos and not the front emblem. If I recall correctly there is pin assembly holding the front emblem , then again I could be wrong.
I just watched my new C6 coupe get built at the factory yesterday and saw them remove the adhesive tape and stick the emblem on the front facia. Unfortunantly I can't tell you how to get it off.
I covered mine with a black CD visor insert $3.00 Ea. at Walmart.
Holds 10 CD ea. and looks pretty good.
Might try reversing the visors but this would put the mirrors on the other side. I would not try to remove the emblem.
