MGW Shifter installed
I used the "factory" ****. It is a custom leather covered one from Gerardo at Down South Vettes. I like the factory **** anyway....
My neighbor showed me his short shifter in his RS4 and it looked like it worked ok but was a bit 'loose'. I took him for my shake-down ride and all he could say was WOW!
St. Jude Donor '09
If you use the stock **** with this shifter, does it RAISE the shifter up some? I've heard that it is different if you use the gripper ****, but I wouldn't want to do that. I just really want the stock **** and stock shifter height (or a bit lower), so this may not work in my situation...
Any comments on the new 'cup' and other updates that George is now providing?
THANKS
I like the stock **** too, John.
THANKS
THANKS
Also does the shifter have any positive stop bolts? The website to order it has no literature on it that I can find.
There are 5 bolts that you use: 4 to secure the shifter and one to secure the **** carrier to the shifter. There are no adjustable bolts that I am aware of or were in the instructions. Total install time was about 1.5 hours - I am slow and meticulous and had two phone calls during the process.
A before pic:
This shifter is EXCELLENT!
St. Jude Donor '09
yeah, if 'a tic higher' is less then I've seen in some other posters' MGW pics, then that's great news!
Wonder if the 25% raises the shifter even LESS??
One other question - The MGW already has a reputation for adding precision to the shifts (theoretically making all shifts 'easier', or at least easier to find), but do you feel that it ADDS a lot of extra shift EFFORT, as well? Again, I assume the 25% would add less extra effort...
The action of my stock '08 shifter seems smooth, but has enough effort already, and certainly doesn't shift as quickly as other (European) cars I am used to...
Thanks again...
Wonder if the 25% raises the shifter even LESS??One other question - The MGW already has a reputation for adding precision to the shifts (theoretically making all shifts 'easier', or at least easier to find), but do you feel that it ADDS a lot of extra shift EFFORT, as well? Again, I assume the 25% would add less extra effort...
Thanks again...
George, being the perfectionist that he is, didn't like this solution so he machined a cup that fit well and wouldn't rattle. Mine came with the new cup.
There were complaints with aftermarket shifters rattling under hard acceleration. Fixes included silicone in the bottom of the factory cup, which it seems most reused.
Thanks again...
Thanks again...
