Weird ...
Old Feb 5, 2008 | 10:33 PM
eliems's Avatar
eliems
Default Weird ...
I just went to open the door on the vette and realized I didn't have my Fob but as my fingers touched the pad the window went down and the door opened. I checked again and no key!
I closed the door and went around to the drivers side but it was locked. Went back to the passenger's side and it was locked.
What's with?
Old Feb 5, 2008 | 10:42 PM
johnodrake's Avatar
johnodrake
Moderator
Is weird... Never heard of that one.
Old Feb 5, 2008 | 11:02 PM
Silver99v6's Avatar
Silver99v6
It happened to me once, but I havent been able to duplicate it.
Old Feb 5, 2008 | 11:09 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Interested to see how this plays out.
Old Feb 5, 2008 | 11:52 PM
gbgary's Avatar
gbgary
you discharged your stored fob capacitance when you opened the door. you'll have to carry the fob another 48 hours to restore the charge. it's in the manual...page 214.
HawaiiC6's Avatar
HawaiiC6
First time I have heard this glitch happening
Old Feb 6, 2008 | 11:39 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
I just reproduced your event. I have autolocking enabled with a horn beep.
1. With the FOB I opened the driver's door, got in and closed the door.
2. Having not started the engine, I opened the driver's door and exited the car.
3. Briskly walked around the back of the car to the passenger fender where I paused.
4. Walked around the front of the car out of the garage and removed the FOB from my pocket.
5. Back into the garage to the passenger door and it opens. I knew it would since there was no beep while I was standing at the passenger side in step 3.
6. Closed the passenger door and walked around to the driver's side at which point the car beeped indicating it was locking.
7. Tried to open the driver's door and confirmed that it was locked.
This refusal to autolock is a very repeatable scenario on my car that others report never happens. If I exit the car and walk briskly around to the passenger side, the autolock doesn't work. I have never found another sequence that results in failure to lock. Others have reported they don't trust the autolock because they once discovered that it didn't work. In other words, the autolock function works for me every time except if I walk around the back of the car and arrive at the passenger door area about the time the autolock is checking to see the FOB is gone. It does not beep to indicate the FOB is still inside, it just doesn't lock.
Old Feb 6, 2008 | 11:55 AM
BigJoe's Avatar
BigJoe
Hmmm, guess my wife will have to get out by herself from now on...
Old Feb 6, 2008 | 11:59 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The window went down by itself???? Never heard of that unless possibly you have one of the auto window devices connected to the OBDII connector. If you do have one of them, then I would be looking at it real quick or removing it. If you don't have it, then a trip to the dealer is needed.
Old Feb 6, 2008 | 12:31 PM
dvilin's Avatar
dvilin
Old Feb 6, 2008 | 02:33 PM
gbgary's Avatar
gbgary
i'm sure he meant indexed down.
Old Feb 6, 2008 | 02:48 PM
Donuts's Avatar
Donuts
I often find mine unlocked even with autolock on.. so i've learned to always lock car as i'm walking away to make sure..
Old Feb 6, 2008 | 03:13 PM
legalgus's Avatar
legalgus
Question - does the horn honk and the door still opens?
Old Feb 6, 2008 | 03:20 PM
RED2008Z06's Avatar
RED2008Z06
Happens to me once in a while, I hang my keys up in my utility room and sometimes the drivers door will open....
Old Feb 6, 2008 | 03:28 PM
anotherone's Avatar
anotherone
What's with?
did it to me too! Quite a surprise.
Old Feb 6, 2008 | 04:10 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
This happens with mine all the time, in fact just this morning. I gave up trying to figure it out as I just accept it now.
Old Feb 6, 2008 | 07:12 PM
richhoff's Avatar
richhoff
I have autolock turned off. I want to hear the horn beep when I push the button and KNOW that it locked. It also makes it almost impossible to ever lock the fob in the car. You pull it out of your pocket and you have it in your hand as you exit.
To Weird ...
Old Feb 6, 2008 | 07:22 PM
User 2623's Avatar
User 2623
Originally Posted by gbgary
you discharged your stored fob capcitance when you opened the door. you'll have to carry the fob another 48 hours to restore the charge. it's in the manual...page 214.
capcitance? do you mean ca·pac·i·tance ?
I'll just look on page 214. Hmmm...
Old Feb 6, 2008 | 07:26 PM
Rowboat66's Avatar
Rowboat66
Originally Posted by FortMorganAl
I just reproduced your event. I have autolocking enabled with a horn beep...
This refusal to autolock is a very repeatable scenario on my car that others report never happens...I
Guess I'll shut the autolock feature off. It may be cool, but it's not worth leaving unknown unlocked.
Old Feb 6, 2008 | 07:28 PM
carnut08's Avatar
carnut08
Not!
