What kind of emblem? A decal/sticker or a raised aluminum/stainless taped on one? If a sticker user heat and goo-gone. If one with tape, saw it off with fishing line and remove the residue with goo-gone. Most are pretty easy to remove. But don't try to just yank it off, you could pull off some paint if you are not careful...
its not a sticker its like a bage ... you knwo ones like z51 or z06
its an aftermarket one
i wanna tkae it off so give me the steps how to do it in safe ways !
You can't go wrong with goo gone and dental floss. Maybe a blowdryer briefly if it's stubborn.
~ then here's your answer. Just take it slow and easy. Work the dental floss in behind the badge -- working it back-n-fourth and if its subborn, use the blowdryer/maybe even a little goo gone to losen it up. Once removed, use the goo gone to remove remaining glue. Just take your time and it should come right off..
