Rpm Question
Thanks in advance
Thanks in advance
I get calls all the time from guys with A6's about this....Most tell me it did so BEFORE the tune...and after.
I will have to look into it.
From what I've been told, A BONE STOCK A6 with NO TUNE will hit the rev limiter in PADDLE MODE.
I'm not sure why it is....Likely a GM oversight.
Personally, I don't like the paddles. I really never got much into them.....but, the way I calibrate the trans....EVERYTHING GM originally did has been scaled up the same....Meaning...Each mode of trans operation has been manipulated by the same amount (ie. shift rpm, mph, and engine rev limiters.) So, in theory it should be no different than when GM did it....That's one of the reasons why my A6 tune is soooo comfortable to drive. It's stock on STEROIDS.
As for the rev limiter, it's been increased by 200 rpm's over what the greaterst shift point increase was. Sometimes auto's will slightly over rev due to the nature of the trans. In this way, it is not possible to have a screw up with my tune.
The A6 has "saftey" calibrations for the paddle mode....I'll review and test them at my next opportunity.
What I need is for someone to "make it happen" and report to me what the exact scenario is so I can have a look at it.....meaning....
I need to know....your RPM's, MPH, and what gear you're paddling INTO when it hits.....so I can find it.
The way it works, you need to pass a specific MPH AND RPM to make it shift at Wide Open Throttle. You could (with wheelspin, trans slippage, or converter flash) exceed one of the parameters...but not the other.....even if by .0000001 MPH or .00000001 RPM you will appear (and think) you are at the correct time to shift....but You'll hit the rev limiter instead.
Let me know and I'll look into it.
Chuck CoW
Chuck CoW
This happened to me before you did my first tune. Forgot I had it in the paddle shift mode, from a very slow roll ( was that 1st gear because I had not shifted from a dead stop? ), got on it and hit the revlimiter quick. Just thought that was the way it worked in the paddle shift mode. Since your tunes and 3.15's I won't even touch the paddles again.
