Solving chin spoiler issue
Old Feb 18, 2008 | 10:55 AM
mickeykelley's Avatar
mickeykelley
Default Solving chin spoiler issue
If the chin spoiler always seems to catch on bumps, etc., why not just permanently remove it? I was thinking of adding a Z06 style spoiler anyways. I did notice that the Z06 still has the chin in addition to the front. Is it an air thing or what?
Old Feb 18, 2008 | 10:57 AM
mksz51's Avatar
mksz51
Are you talking about a chin spoiler or an airdam. "Standard" C6 does not have a chin spoiler. ALL C6 have an airdam.
Old Feb 18, 2008 | 11:15 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
The air dam directs cool air up into the engine compartment, some guys have cut it down, I wouldn't remove mine.
Old Feb 18, 2008 | 11:25 AM
mickeykelley
I guess I mean the air dam, or the whatever you call the DAMN (pun intended) thing that is always scrapping when you hit a small bump, angle drive ways, etc.
I guess the answer is that you keep it go deflect the air up to the engine. I guess what I see on the Z06 is called a chin. Do they make one that bolts right up to a regular C6?
Old Feb 18, 2008 | 11:26 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The 3 piece air dam serves two distinct purposes. First is to direct cooling air up to the radiator. Second is to provide high speed stability by preventing a mass of air travel unimpeded under the car which will cause the front to lift and create a light front end at very high speed.
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Which would be verry bad!
Old Feb 18, 2008 | 11:29 AM
edv2122's Avatar
edv2122
I removed the side parts of the air dam and left the center piece. Much less scrapping as the sides would catch first on bumps becuase they are further up. Side benefit is the front looks cleaner because you can't see the center piece as much with the sides pieces removed. I like the look better.
Old Feb 18, 2008 | 12:19 PM
Low Rider's Avatar
Low Rider
I cut one inch off the bottom of mine on my lowered car and have hardly any scraping sounds now. Have not noticed and increase in engine heat plus it looks better.....
Old Feb 18, 2008 | 12:36 PM
talon90's Avatar
talon90
NCM Ambassador
Unless you are doing track days or a lot of hard driving you likely won't notice any elevated temperatures. The C6 nose allows for functional airflow to the radiator but it shares that duty with the air damn on the bottom. The C5 was much more dependant on the air damn as the nose was closed so it was more of an issue.
Old Feb 18, 2008 | 12:41 PM
Kent1999's Avatar
Kent1999
The air dam is made of black _flexible_ plastic because it *will* scrape on driveways, speedbumps, intersection rain dips, etc. Just the way it is.
It's a street car... drive at angles across such things when safe to do so, and don't sweat it when it does scrape. It's made to take it.
Old Feb 18, 2008 | 12:45 PM
rayainsw's Avatar
rayainsw
Default trimmed - how?
How did you cut it?
Did you need to remove it from the car first?
Thanks,
- Ray
Many, many scrapings.......
Old Feb 18, 2008 | 12:48 PM
mickeykelley
I am more worried about the appearance of my drive way after time. I have a down slope that then evens out before I pull in. I won't be able to take it at an angle. We have not poured the cement yet so I don't know for sure if it will be an issue or not.
Old Feb 18, 2008 | 12:53 PM
Rapnrev's Avatar
Rapnrev
I found the C5 air dam to be better that the C6 it was more flexible from both directions going forward and backwards. Where as the C6 has great flex when you go forward over things but less give when you back over things. Mine broke off on the passenger side of the car.
Old Feb 18, 2008 | 01:30 PM
ohmy's Avatar
ohmy
Don't F with the air dam, just let it scrape and don't worry about it...
Old Feb 18, 2008 | 02:13 PM
orca1946's Avatar
orca1946
Sooner or later it will wear down by itself.
Old Feb 18, 2008 | 02:16 PM
Snagle's Avatar
Snagle
The air dam is designed to scrape...that is why is it flexible! If it wears or breaks from excessive scraping, it may be easily and inexpensively replaced. Don't worry about it.
Old Feb 18, 2008 | 02:41 PM
IdaGuy's Avatar
IdaGuy
Not trying to hijack the thread but does anyone have instructions on how to remove the air dam? I done a thread search and can't come up with anything. My existing one is beat up and I would like to replace it.
To Solving chin spoiler issue
Old Feb 18, 2008 | 02:45 PM
Vetteoholic's Avatar
Vetteoholic
Plus they are designed to scrape, it would take one heck of a hard scrape to rip it off. I also wouldn't take it off If I were you. You could trim it down as mentioned above if it bothers you that much.
Old Feb 18, 2008 | 03:03 PM
torquetube's Avatar
torquetube
Default Keep the air dam
Not for esoteric cooling/aerodynamic reasons, but for this reason: the audible scraping is your early-warning alert that the painted bumper cover is getting close to the ground. Scraping the flexible air dam is fine, but you definitely don't want to scrape the bumper cover.
Also, it looks better on.
Old Feb 18, 2008 | 03:09 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
