DSV E-brake boot/BRAKE light
Old Feb 20, 2008 | 10:35 AM
GizmoZ's Avatar
GizmoZ
Default DSV E-brake boot/BRAKE light
I installed my new DSV ebrake boot and handle last night. The install went smoothly, no problems there. The only thing is with the increased mass of the leather boot and the increased resistance, the handle doesn't want to stay all the way in the down position. It is being pulled slightly up maybe 1/8" and is on the edge of triggering the BRAKE light on the instrument cluster.
Anyone else experience this? I have moved the boot around in different positions and worked the slack around in different places but it doesn't seem to make a difference either way. Will the leather stretch out enough over the next several uses to eliminate this?
Old Feb 20, 2008 | 10:36 AM
DS Vettes's Avatar
DS Vettes
Leather will stretch out probably withing a 2 week period.
Gerardo
www.dsvettes.com
Old Feb 20, 2008 | 11:06 AM
GizmoZ's Avatar
GizmoZ
Okay thanks Gerry. The quality of the leather and stitching is awesome. Thanks for all the great products you offer us.
Old Feb 20, 2008 | 12:39 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yep, mine did the same thing. It just needs to break in so to speak. It will get better with use and time. Mine took a few weeks for the leather to soften up and stretch.
Old Feb 20, 2008 | 02:22 PM
AgDriller's Avatar
AgDriller
Maybe if you put a weight of some kind (book, piece of wood??) on it when not driving, it would speed up the process.
Old Feb 20, 2008 | 02:35 PM
scichoski's Avatar
scichoski
pics?
Old Feb 20, 2008 | 02:38 PM
lsbrodsky's Avatar
lsbrodsky
Mine took a little longer because I painted the e-brake button while it was all apart.
Old Feb 20, 2008 | 02:41 PM
johnodrake's Avatar
johnodrake
Moderator
Mine did.. I put a bit of Zaino Leather in a Bottle and that helped.
Old Feb 20, 2008 | 02:51 PM
redzone's Avatar
redzone
Mine too.....well worth it!
Old Feb 20, 2008 | 10:00 PM
BlackMark's Avatar
BlackMark
Same here-it just took a couple weeks and it works normally(and looks great!).
Old Feb 21, 2008 | 10:20 AM
GizmoZ's Avatar
GizmoZ
I'll snap a couple of pics today after work. I went with the subtle theme. Ebony leather with titanium stitching to match my 2008 console and seats.
I also applied some leather conditioner to help soften the leather. I will probably lay something over it as AgDriller suggested since I'm not driving the car much yet due to intermittent crappy weather.
Thanks again guys.
Old May 11, 2008 | 02:21 PM
SimonStern's Avatar
SimonStern
Mine is doing this too, so it's good news that it will get better with time.
I just did ebony with cashmere stitching for the ebrake and shift boots. Very high quality, and look fantastic!
Old May 11, 2008 | 02:40 PM
wayback's Avatar
wayback
Mind did the same thing. Put leather cond. on it and park in the sun for a day. Work e brake up and down while holding boot next to handle and at rear latching point. Will speed up the leather stretching process.
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Mine was doing that too and after the boot broke in, no more brake light issues.
Old May 12, 2008 | 09:14 AM
GizmoZ's Avatar
GizmoZ
Yep, just give it some time and it will work great. Mine has no resistance in its travel anymore.
To DSV E-brake boot/BRAKE light
