You are correct on what you need. The front calipers are identical and I believe there is a slight difference in the piston diameter of the rear caliper (but they'll work just fine).
...brackets & rotors and you're good to go. FYI, the non Z51 rears are 35MM and the Z51 are 32MM, but they can be interchanged with no issues.
