2008 build date
Old Mar 12, 2008 | 05:46 PM
switchplanner's Avatar
switchplanner
Default 2008 build date
Just got the build sheet for my car from the Corvette Museum and was hoping it would have the build date on it (it doesn't). Any way to find out when my car was built? BTY, did a search and nothing came up.
Old Mar 12, 2008 | 06:13 PM
Bubbatex's Avatar
Bubbatex
PM me your VIN and I will look it up for you.
Old Mar 12, 2008 | 06:29 PM
switchplanner
PM sent. Thanks.
Old Mar 12, 2008 | 07:07 PM
Victoryred 08's Avatar
Victoryred 08
St. Jude Donor '08
Congratulations on the order of your new Vette.
Old Mar 12, 2008 | 07:12 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Unfortunately as you have found out, the build sheet does not contain the build date of the car. It looks like you have a couple of offers to get it so that is a good thing. The build sheet is a recepie if you will of how to make your car, not when. It simply contains the options and the detail of the features that went in to your car. It is used by the production and quality folks to assemble and validate the assembly of your car.
Old Mar 12, 2008 | 07:52 PM
pTr73's Avatar
pTr73
I have learned that the car is on the actual production line for about 33 hours so it isnt built in one day... That being the case I assume the TPW (Target Production Week) is what is considered a build date. Am I right? Unless the day the car comes off the production line is said to be a build date, I dont know, just guessing here.
Old Mar 13, 2008 | 06:10 PM
switchplanner
Thanks for the responses and well wishes The build date for my '08 coupe appears to be 9/21/07 according to info provided by a forum member. This sounds right as I bought it on 10/19/07.
STW
Old Mar 13, 2008 | 06:17 PM
940CACC's Avatar
940CACC
STW
call your dealer and get the order number and few other things I can't remember.....and call GM. I did that last week and got my build date of April 7th.
good luck and I can't wait until the end of April when she should arrive
To 2008 build date
