Vin question..........
Old Mar 13, 2008 | 12:50 PM
Frank C's Avatar
Frank C
Default Vin question..........
Gentlemen; On a 2006, if the 8th position on the vin is a U, what does that tell you? I'm pretty sure this means that the engine is an 6.0L LS2 but I'd like conformation.
Thanks, Frank
Old Mar 13, 2008 | 12:51 PM
Kent1999's Avatar
Kent1999
Yes, that is exactly what it means.
Cheers,
Kent
Old Mar 13, 2008 | 12:54 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You are correct, it indicates an LS2 engine.
This is an example of a VIN # for a 2006 Corvette Coupe:
1 G 1 Y Y 2 6 U 3 6 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
1. "1"= Built in US
2. "G"= General Motors
3. "1"= Chevrolet
4. Denotes the car line: Corvette is a "Y" body.
5. Provides more info about the car:
Usually a "Y" but the ZR-1 is "Z"
6. Body style: "1" = FRC, "2" = Coupe, "3" = Convertible
7. Restraint code
8. Engine:
L98="8"
LT1="P"
ZR1="J"
LT4="5"
LS1="G"
LS6="S”
LS2=”U”
LS3=”W”
LS7=”E”
9. Check Digit – 0 to 9 or X
10. Model year:
"B" thru "N" are yrs '81-'92 respectively
"P"='93
"R" thru "T" '94-'96
"V"='97
"W"='98
"X"='99
"Y"='00
"1"='01
“5”=’05
“6”=’06
“7”=’07
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #1 for each model yr.
Old Mar 13, 2008 | 01:05 PM
Frank C's Avatar
Frank C
Thank you very much...........Frank
To Vin question..........
