Dual Batteries
Old Mar 18, 2008 | 02:57 PM
antt's Avatar
antt
Default Dual Batteries
Is the rear passenger side compartment in the C6 coupe the same size and position as the Z06? If so, has anyone installed a second battery in parallel with the standard battery?
Thanks!
Old Mar 18, 2008 | 03:04 PM
BigJoe's Avatar
BigJoe
Not sure why I would want to do that...
Old Mar 18, 2008 | 03:07 PM
V-Dub's Avatar
V-Dub
+1
V-Dub
Old Mar 18, 2008 | 03:26 PM
cclive's Avatar
cclive
It would take twice as long for it to run down....thats a good thing...
Old Mar 18, 2008 | 03:41 PM
antt's Avatar
antt
Just a thought to effectively double the amp-hour capability. Even the Optima and Odyssey batteries are minor improvement on the stock battery in this regard.
Old Mar 18, 2008 | 03:46 PM
mksz51's Avatar
mksz51
Too much weight for really no apparent gain.
Old Mar 18, 2008 | 04:36 PM
su8pack1's Avatar
su8pack1
Old Mar 18, 2008 | 04:52 PM
antt's Avatar
antt
Must be a dumb idea. Personally, the additional 35 pounds would be a small price to pay to avoid the dreaded DBS.
Old Mar 18, 2008 | 04:53 PM
Kent1999's Avatar
Kent1999
Thanks!
The C6z frame has an additional welded-on battery platform to support the battery weight on the frame rail (circled in green in the pic below). The C6 coupe/convertible frame does not have this platform.
So if, for whatever reason, you wanted to add/relocate a battery to the back of a C6 coupe, you'd have to fab up a support bracket to carry the weight.
Cheers,
Kent
Z06 frame with battery support shown:
Old Mar 18, 2008 | 04:54 PM
johnodrake's Avatar
johnodrake
Moderator
I've not experienced a battery issue... so I don't see the need
Old Mar 18, 2008 | 05:01 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
So if for whatever reason you wanted to add/relocate a battery to the back of a C6 coupe, you'd have to fab up a support bracket to carry the weight.
Cheers,
Kent
Thanks for the info on this, and seems the relocation will need a kit or the afore mentioned fab
Old Mar 18, 2008 | 05:20 PM
VET4LES's Avatar
VET4LES
Three years and no DBS.
Old Mar 18, 2008 | 06:48 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Don't see a need.
Old Mar 18, 2008 | 11:37 PM
cclive's Avatar
cclive
Nice info Kent! The perfect picture to show the area.
The extra battery doesn't have to be as big or heavy as the main one in order to help out though. There are lots of different deep cycle batteries out there to choose from..
Old Mar 18, 2008 | 11:39 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Cool idea for back up and or heavy stereo system.
Old Mar 18, 2008 | 11:57 PM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Originally Posted by V-Dub
+1
V-Dub
+2
LMB
Old Mar 18, 2008 | 11:59 PM
Mike's Sweet 19's Avatar
Mike's Sweet 19
antt,
If you are thinking about adding another battery to support the main one you are openning a big can of electrical worms. Since batteries have an internal resistance their charge and discharge rates can be different to the point that if the main battery is detoriated it will drain the aux battery.(Unless they are matched batteries $$$$$)
If you go forward, I would suggest putting some current carrying diodes between the negative terminal of each battery and the connecting cable.
The best solution is to get a better battery than the junk delco's. Diehard is a good replacement and they make type 86 batteries.>$100 for 8 year warrenty.
Mike
To Dual Batteries
Old Mar 19, 2008 | 08:25 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
35 pound battery with several installation issues or a 3.5 ounce wire and quick connector for a Battery Tender. Both could prevent DBS.
Old Mar 19, 2008 | 10:27 AM
User 020720's Avatar
User 020720
No need for me either.
Old Mar 19, 2008 | 10:48 AM
NYC6's Avatar
NYC6
Just think how safe youll be if you add 2 or 3 batteries back there.
