convertable top question-help??
Old Mar 22, 2008 | 11:07 PM
LT1driver's Avatar
LT1driver
Default convertable top question-help??
05 convertable...there is a thread on the lower side area that appears to hold everything together (top panels) for a tight correct fit, mine is cut and hanging loose about 8 inches on drivers side. it is about the size of a round shoe lace...does anyone have any idea what it is and where I can buy one, catalogs don't seem to show it. I know it is a poor description of what it is but don't know how else to explain it. thanks for any help you can give me.
Old Mar 22, 2008 | 11:13 PM
RicK T's Avatar
RicK T
Probably needs to go to an upholstery/top shop. Is it still under warranty? I can't visualize what you are talking about but I think I would get it fixed soon. JMO.
Old Mar 22, 2008 | 11:28 PM
luvlake's Avatar
luvlake
I have an 08 Vert with manual top and know what you are talking about. That string or cord is what makes your side panels behind the driver and passenger on the roof (side) be tight. The first time I let my top down and put it up one side was sagging. Now I just make sure both sides are tight by pulling down on the cord. Look at the other side and use it as a guide as to how/where the cord is placed. As I recall it snakes around a bit and is tied at the bottom or held with a round groument. It may have just came undone and all you will have to do is route it similarly to the other side and secure it to the groument/bottom. If it broke I guess I would take it to someone who installs convertible tops and see if could be fixed. I doubt a dealer knows how to fix based on the one's I have seen and their knowledge or lack of knowledge of a Corvette. Good Luck!!
To convertable top question-help??
