On todays motors all the crank case vapors are recycled into the intake to be burnt in the combustion process. A catch can catches any oil that is in the vapor and stores it for disposal. You would be shocked at the mess in the intake from the oil
Wouldn't the oil in the intake get mixed in with the fuel and burnt up in combustion? How would this be robbing horsepower or causing any issues down the road?
I had one on my SVT Lightning but that was a supercharged motor. I had no idea that naturally aspirated motors would ever need one. I had to empty the Lightning's can about once a month, about 1 oz each time. Any idea how often an LS2 needs to be emptied? I remember a major factor was driving style. For instance, I took the SVT to the drag strip a lot and the more WOT runs I made the faster the can filled up. Daily driving hardly ever deposited any oil in it.
When I swapped my stock intake manifold for a ported I/M, I had oil on the bottom of the stock I/M. The oil made its way down to the portholes. So I installed a catch can.
I do, however, do high revs, and maybe that's why the oil seeped thru.
