MGW Replacement Center Shaft Installed
Old Mar 26, 2008 | 08:53 PM
Blue 2's Avatar
Blue 2
Cruising
Default MGW Replacement Center Shaft Installed
About two weeks ago I installed a 30% MGW shifter. I was very pleased with the increased precision in shifting. Two days ago I received a package from MGW that included a replacement center shaft. The new one is designed for better side to side movement and better resistance to heat issues with racing applications. I didn't look forward to pulling the center console again, but decided it had to be done. Today I installed the improved center shaft. The job took just a little over an hour to complete and I found that lessons learned from the fist console removal really helped out. The procedure is very straightforward with good written instructions provided. After a test drive I can say without doubt that MGW has taken a great product and made it even better. Super precise shifting with no rattles or noise whatsoever. A great mod for the money. The original shifter is in the mail back to Georgia as requested.
Old Mar 26, 2008 | 10:22 PM
iridelow's Avatar
iridelow
OK....How much?
Where can I get it?
What difference is ther? My MN6 shifts greAT AS IT IS........
Old Mar 26, 2008 | 11:37 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
My shifter should arrive on Friday. I'm assuming it already has the change made to it. I can't wait to get that sucker in the car!!!
Old Mar 26, 2008 | 11:43 PM
Swiftrider08's Avatar
Swiftrider08
Originally Posted by iridelow
OK....How much?
Where can I get it?
Ok, where have you been? We have all been talking about the MGW shifter for months now. Mine is on order. I really think you will want this shifter after reading all the great things about it. Do a search for MGW shifter. Can't believe you have missed this as I know you are on the forum often.
To MGW Replacement Center Shaft Installed
