2005 question
Old Mar 31, 2008 | 01:46 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Default 2005 question
Hi Guys
First time on the C6 section[ I own a C5]. A friend just bought a black 05, 6 speed, with 21k on it. Didn't know she was going to get it. Guess it was a surprise. A friend of mine had a 05 that he finally had to turn in because of constant problems with the DBS[ dead battery syndrome]. I've heard of this problem with many 05's and was wondering how much of a problem this was. Anyone out there have any input on this? I've been on this girl for a long time to get rid of her Audi and get a vette. Sure don't want her to have any problems with it. So far she loves it.
Old Mar 31, 2008 | 01:54 PM
St.Char's Avatar
St.Char
When letting the car sit for more than a week or 10 days, it's good to always put a battery tender on it. Problem solved!
H&J's Avatar
H&J
No problems with mine. Just put it in reverse when you turn it off, make sure the steering wheel locks, then open the door to get out.
I know it sounds weird but the one and only time I had DBS was when I opened my door before shutting down the engine. Ever since then it's been reverse, shut down, steering lock, door open. Never had DBS again.
Old Mar 31, 2008 | 02:03 PM
mforman42's Avatar
mforman42
Never had an issue with my '05 MN6...
Old Mar 31, 2008 | 02:21 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Thanks for the info. I'll pass this on to her.
Old Mar 31, 2008 | 02:30 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'm suprised too, but I thought I read there's also a reflash of the computer for this that helps. Plus, make sure this is a battery tender, not a trickle charger or charger. It costs relatively little; about 25 even at autozone, pep boys, etc. And reverse is mandatory.
Also, remember that all the sockets are "hot" always. Meaning, if you leave a GPS or cell phone charger in it, and turn off the car, it's still charging away, draining the battery. Finally, I've heard (not just '05s) that those who wash, wax and otherwise fix their cars can't leave their stereos on for a long time without draining the battery. I don't know this for a fact, just read it here a few times. So, be careful or try it out and see if it happens.
Old Mar 31, 2008 | 02:35 PM
RicK T's Avatar
RicK T
There was a TSB software reflash for the DBS. I don't have the info handy but someone who does will probably come by.
Off your topic, there was also a software update for the '05 nav (if she has one) to allow for MP3 play.
IMO you should check to see what has been done to the car and get the important updates if not done already. You can PM a couple members to do that, gmautotech and bubbatex, with the VIN:
bubbatex here with a sample report:
http://forums.corvetteforum.com/show...15&postcount=2
gmautotech here:
http://forums.corvetteforum.com/member.php?u=221526
Good luck and Congrats to her!
Old Mar 31, 2008 | 02:39 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Thanks. I'm sure the dealer will help her out with any questions she might have. So far they've bent over backwards to help her. Even free oil changes. Of course, it sure helps that shes a foxy lady!
Old Mar 31, 2008 | 02:42 PM
redvetteC6's Avatar
redvetteC6
From: Huntington Beach Ca 1 out of 4 Americans are mentally unstable, so if 3 of your friends are OK . . . .
St. Jude Donor '05
Never had a DBS problem, ever. Built 1/21/05. It has sat for month while I was in Europe and several 3 week stints. Gets driven 3-4 times a week depending on where I have to go (no stop n stop traffic for this MN6!)
Old Mar 31, 2008 | 02:46 PM
SpdWhite's Avatar
SpdWhite
I have an 05 with MN6 and have had DBS a number of times. Last spring I got my third battery and had the re-flash. Seemed to be good after that.
Just waiting for good weather to take it out this year.
Old Mar 31, 2008 | 02:57 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
I have an '05 and have never had a battery problem. I DO NOT drive my car everyday and it always cranks up. Sometimes it sits over a week and still no problems.
Old Mar 31, 2008 | 03:02 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
Mine sits for 2-3 weeks at a time during the winter without being started.
Old Mar 31, 2008 | 03:15 PM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
Same here....And now at 73,000 miles
Old Mar 31, 2008 | 03:16 PM
moolys's Avatar
moolys
St. Jude Donor '09
mine was a late build O5 Aug never had any problems except a few minor recalls
Old Mar 31, 2008 | 03:17 PM
not08crmanymore's Avatar
not08crmanymore
Damn!!Good for you!
Never an issue w.the battery in my 05 mn6 z51 in the 2.5 years I owned it.I did hook up a battery tender after a while just in case.
Old Mar 31, 2008 | 03:35 PM
VET4LES's Avatar
VET4LES
No problem here either. DBS was a problem for a very few 05's and the reflash seems to have taken care of it.
Old Mar 31, 2008 | 04:09 PM
POPA-VT's Avatar
POPA-VT
I've had my 05 mn6 for a year and have had no problems. Had it stored all winter with battery tender. Started right up yesterday. Don't drive it every day, but have gone a week or so without using it and usually starts right up.
Old Mar 31, 2008 | 04:10 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I had a 05 with 5 DBS attacks. The Flash they came out with fixed it.
"TRUE" DBS was a huge problem on the forum in 05-06. Now you hardley here about it much any more.
What comes on here now is battery problems that all now call DBS.
"True" DBS was at the time we started calling it was a 05 manual shutting down by the numbers and the battery going dead in about 3 days. Later the DBS named morphed into any battery problem.
Search under my name, I had tons of stuff on it then
To 2005 question
