Jacking Pucks ?
Old Apr 8, 2008 | 11:51 AM
mickeykelley's Avatar
mickeykelley
Default Jacking Pucks ?
So all I have been reading about these jacking pucks.......You don't leave them installed all the time, but I guess you need them to lift the car. If you take it to a tire shop, do you assume they have them or just carry them with you in the car all the time, just in case?
What are most of you doing?
Old Apr 8, 2008 | 12:01 PM
ruby9246's Avatar
ruby9246
St. Jude Donor '03-'05-'06-'07-'08
I bought a set that snap on and i leave them on the car all the time.
Old Apr 8, 2008 | 12:06 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I jack it with a jack on suitable jacking points...you dont need jacking pucks.
Old Apr 8, 2008 | 12:07 PM
RadarP3C's Avatar
RadarP3C
I keep mine in the rear cubbies. I would not assume the shop you take yours to has them or even knows how to use them.
Old Apr 8, 2008 | 12:11 PM
keg's Avatar
keg
I keep a set of four wraped up in cloth and stored in one of the little compartments in the rear just in case I need to use them.
Old Apr 8, 2008 | 12:15 PM
carpe dm's Avatar
carpe dm
I carry a set of hockey pucks with me; you never know when you might need them.
Old Apr 8, 2008 | 12:40 PM
cclive's Avatar
cclive
Old Apr 8, 2008 | 12:41 PM
mickeykelley
Where are you buying your? About how much?
Old Apr 8, 2008 | 12:45 PM
CodyC6's Avatar
CodyC6
Go to Bavarian Autosport
www.bavauto.com $7.95 each
Part# 51 71 8 268 885
Or go to local BMW dealership.
They snap in, and I leave mine in permanently. I use the rectangular item.
Old Apr 8, 2008 | 12:54 PM
STEVE MC's Avatar
STEVE MC
Keep them in the car at all times........Unless you have the kind that lock in and stay on the rocker panel
Old Apr 8, 2008 | 01:11 PM
FlyBono24's Avatar
FlyBono24
Mine are autographed by Wayne Gretzky!
Old Apr 8, 2008 | 01:29 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
I had Don Rickles autograph mine.
Old Apr 8, 2008 | 01:38 PM
70454's Avatar
70454
I have the Bavarian round ones.
Old Apr 8, 2008 | 01:48 PM
dvilin's Avatar
dvilin
Old Apr 8, 2008 | 03:08 PM
ROC OUT's Avatar
ROC OUT
Generally speaking, the jacking pucks that are inserted into the slots in the rocker arms (space between the tires below the doors) are used when the car is lifted by a "four points" hydraulic lift. These are the types of lifts you see in an automotive shop. I think some here use the jacking pucks in the rocker arms when they want to lift the car with a floor jack. However, the owner's manual indicates that other jacking points are designated/available for lifting the car with a standard floor jack.
Personally, I have never lifted my car from the rocker arm slots as I feel that doing so with a floor jact puts undue stress on the vehicle frame. Rather, I prefer to lift from the jacking points underneath the car as indicated in the manual. Just my opinion.
Old Apr 8, 2008 | 03:22 PM
User 020720's Avatar
User 020720
I use these ones from Ecklers.
http://www.ecklers.com/product.asp?p...6&dept_id=1095
I am not fond of the aluminum pucks.
Old Apr 8, 2008 | 03:28 PM
lurtonk's Avatar
lurtonk
I have a set of rocker rails installed that extend about 1/4inch below the rocker panel. It gives me about 5 feet length of jacking area directly below the frame rails. I take the cup off of my floor jack and just use the flat.
The rocker rails purpose is to keep the rocker panels from being damaged on high speed bumps, driveways, etc. but they are also great for jacking from the side.
To Jacking Pucks ?
Old Apr 8, 2008 | 03:35 PM
genex's Avatar
genex
as a former hockey player...i keep my pucks in the fridge tull i need them....lol
Old Apr 8, 2008 | 04:44 PM
Atomic Autosports's Avatar
0Atomic Autosports
Former Vendor
Originally Posted by cclive
They work great and there cheap.
Old Apr 8, 2008 | 07:19 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Got my set of 4 from eBay- do a search on eBay motors for corvette jacking pucks.
Mine were delivered for ~ $20.00. Keep them in a gallon baggie in a rear compartment.
