Check Gas Cap Message
Old Apr 9, 2008 | 04:36 PM
TBonez's Avatar
TBonez
2005 Beast
Default Check Gas Cap Message
Guys,
I know the gas cap is horribly cheap but mine isnt broken but I keep getting the error msg. Any way to fix that and are there better quality gas caps you can buy?
thx,
Bonez
Old Apr 9, 2008 | 04:41 PM
HawaiiC6's Avatar
HawaiiC6
You need to check as the cap may seem like it is going on and you will hear the clicking but the cap is only spinning. You need to lube the cap threads with WD40 or a silicone spray to allow it to go on without binding, also don't push and turn.
Old Apr 9, 2008 | 04:42 PM
keyplyr's Avatar
keyplyr
It happens to a lot of us.
It's a warranty item, so the dealer should replace it free. Took 5 minutes for me. Problem solved.
Old Apr 9, 2008 | 04:43 PM
TBonez's Avatar
TBonez
2005 Beast
Will have to try that, thanks.
Old Apr 9, 2008 | 04:44 PM
TBonez's Avatar
TBonez
2005 Beast
That's definetly an option thanks.
Old Apr 9, 2008 | 04:48 PM
CQRT's Avatar
CQRT
You can do a search within these pages on "gas caps" and find that your experience isn't unique....lots of folks with seemingly good caps, tightened the extra clicks and still the DIC message.
Get a new cap from the dealer and drive a bit--it should reset. Good luck.
Old Apr 9, 2008 | 05:59 PM
TBonez's Avatar
TBonez
2005 Beast
Did that and some info helpful. The WD40 thing I tried, gonna see the next time if it worked, when I start the car it still comes on but after I clear the DIC haven't noticed it yet, not sure how long it waits to display it again. Might be a leak somewhere that is throwing the sensor.
Old Apr 9, 2008 | 09:02 PM
VetteMark's Avatar
VetteMark
I had to get my replaced by the dealer.
To Check Gas Cap Message
