Throttle Body Spacer?
Old Jan 17, 2009 | 01:11 PM
HOXXOH's Avatar
HOXXOH
Originally Posted by Stage Runner
Gotta disagree with you sir, the TBS does not increase volume. The spacer increases plenum/intake runner length. Air volume is dictacted by engine RPM, incoming air pressure with regards to altitude-ram air-and/or mechanically assisted and the smallest opening incoming air has to pass through.
However, any HP gains are seen at WOT. Therefore, a 1" longer connector hose would accomplish the same result as the 1" spacer.
Old Jan 17, 2009 | 01:12 PM
HawaiiC6's Avatar
HawaiiC6
As you posted which is the TBS increases the TB to plenum length (it does not increase the intake runner length) that means you have more air in your intake. Common sense will tell you that incoming air pressure is increased because of the increase in plenum area due to the TBS.
Strange that you disagree with me yet you post the exact reason why the TBS will work.
Old Jan 17, 2009 | 01:36 PM
stoessjc's Avatar
stoessjc
Per Vararam instructions (verbal), I installed the intake, ran for a couple hundred miles, then installed the TB spacer. I could feel better throttle response. I was surprised. The rubber spacer comes with metal inserts that go into the bolt holes and prevent the spacer from being overtorqued.
John
Old Jan 19, 2009 | 02:11 PM
THE TECH's Avatar
THE TECH
Anyone know who makes an aluminum one? The Vararam is a poor design with the material they use.
Old Jul 2, 2009 | 12:51 AM
InMyRearView's Avatar
InMyRearView
i wanna bring this thread back to life... are there any aluminum ones out there? (posted above)
i did see the Vaaram one and i was looking into it but then i read a couple of horror stories about them too and i dont want to fall victim to that too. i do not have the vaaram intake, would this throttle body spacer still work? Thanks.
Old Jul 15, 2009 | 05:50 PM
browner30's Avatar
browner30
would like to know the answer to this question also...???
Old Jul 15, 2009 | 07:58 PM
Spectrel's Avatar
Spectrel
I'd be in for an aluminum one as well
Old Jul 15, 2009 | 08:45 PM
Greg A's Avatar
Greg A
Default Spacer
If you are willing to come and pick it up, I have one (free) with your name on it!!
Old Jul 15, 2009 | 09:03 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
if you do install it,, dont over tighten it.. they have been known to distort and cause vacuum leaks.
