Broken spring found on drivers side floor???
Old Apr 11, 2008 | 08:39 PM
C5FlyerGuy's Avatar
C5FlyerGuy
Default Broken spring found on drivers side floor???
My wife was driving our C6 and she heard a "snap" as she was using the clutch. She said everything seemed to be fine but when she got home I found a broken spring on the drivers side floor. It must have fallen out from under the dash somewhere. It's about 1.5 inches in diameter. I havnt been under there yet but I wonder if anyone knows what might have happened here.
Thanks,
Tom
Old Apr 11, 2008 | 08:40 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It sounds like you (she) broke the clutch return spring. It has happened to a few members. It is a pretty easy and cheap replacement. Some have just left it off and some have swapped it with the C5 spring for a slightly better feel.
johnodrake's Avatar
johnodrake
Moderator
Most likely the clutch assist spring.
Old Apr 11, 2008 | 08:42 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
happens apparently
http://forums.corvetteforum.com/show...h+pedal+spring
Old Apr 11, 2008 | 10:27 PM
cclive's Avatar
cclive
Remember there is a difference between return and assist...assist is under the dash
Old Apr 11, 2008 | 11:55 PM
Thrill6's Avatar
Thrill6
There is only one clutch spring, and it does both and the reason most people hate the C6 spring. It makes the clutch pedal pressure very uneven. For the first half of travel, the spring is being load and requires more pressure on the cluck pedal to push it in, and then because of the geometry, the spring reverses on itself and then pulls the clutch back for the last quarter. The result is that when almost out, it pushes the clutch pedal up (a return spring), but when the clutch is almost to floor it helps pull keep the pedal in (assist spring). I replaced mine with a C5 spring and I love it. The cheapest (I think it was $6 from Gene) and best mod I've done to the car. The clutch pressure is much more linear because the C5 spring is much smaller. It still pushes the clutch pedal when almost all the way out, and offers much less "assist" when the pedal is all the way in. The only time I miss the old C6 spring is when I'm stuck in city traffic.
Old Apr 12, 2008 | 12:11 AM
adias's Avatar
adias
That spring serves a purpose. replace it or you will have clutch wear.
Old Apr 12, 2008 | 09:50 PM
C5FlyerGuy's Avatar
C5FlyerGuy
Default Thanks for the input
Appreciate the feedback and the link to the thread. Drove the car today and it was fine. In fact I liked the way the clutch felt without the spring. I'll probably replace it just to be on the safe side.
Does anyone know if you just pop the spring on or is it more involved?
Thanks,
Tom
Old Apr 12, 2008 | 09:54 PM
JJC5's Avatar
JJC5
I think it's a good idea to replace the spring. As said above, it's there for a reason.
Old Apr 12, 2008 | 09:56 PM
VET4LES's Avatar
VET4LES
Old Apr 12, 2008 | 10:00 PM
JJC5's Avatar
JJC5
Originally Posted by VET4LES
Hi Les! Can you make the get together in Corona tomorrow?
To Broken spring found on drivers side floor???
