Brake squeal gone.
Old Apr 25, 2008 | 01:10 PM
larvette's Avatar
larvette
Default Brake squeal gone.
Today the dealer installed gm durastop ceramic brake pads front and rear on my 08 AO NPP Z51 coupe. Pads came chamfered with anti squal shims on them. Car only had 350 miles on it but squealing was very loud. tried bedding in the original pads but it did not work out. Very happy with the results.
Old Apr 25, 2008 | 01:13 PM
JJC5's Avatar
JJC5
Sounds good. I have Z51 and have heard lots of complaints about squealing but I have never had any (8,000 miles). I like the idea of reduced brake dust though.
Old Apr 25, 2008 | 01:21 PM
SilverScorp's Avatar
SilverScorp
I replaced my Z51 pads with Prostop ceramic pads from Pepboys. The fronts were $80/pair and back were $40/pair. Squeal is gone and stopping is much better than the old ones. They also come with antisqueal shims (black) attached. The part number was 731C (Front) and 732C (Back)
Old Apr 25, 2008 | 01:41 PM
redjetty's Avatar
redjetty
so, was it covered under warrenty??
Old Apr 25, 2008 | 01:51 PM
larvette's Avatar
larvette
Yes there was no charge.
Old Apr 25, 2008 | 01:53 PM
Batmbl's Avatar
Batmbl
Had dealer install ceramics last week and turn rotors. Still squeaks, only a higher pitch. Will ask about shims, but shouldn't have to if I paid to have the problem fixed. Glad yours worked out.
Old Apr 25, 2008 | 04:40 PM
Darth_Vader's Avatar
Darth_Vader
I've had my vette for a little over a year. The brakes still squeal in certain weather conditions..... Luckily my borla exhaust system hides that.
Old Apr 25, 2008 | 05:20 PM
St.Char's Avatar
St.Char
Now is the time to bed in those new pads.
Old Apr 25, 2008 | 08:08 PM
Tom_Slick's Avatar
Tom_Slick
Wow, wonder if they'll throw in a set of drilled rotors too? Never thought I could have got them for free from the dealer. I just saw on CNET on my TIVO, they tested a 911 Carrera 4S... On a $100K car, ceramic pads are a $8100 dealer option!
Old Apr 25, 2008 | 11:29 PM
danl72's Avatar
danl72
That's insane. Forget the option and go out and get them yourself.
Old Apr 25, 2008 | 11:42 PM
DZeckhausen's Avatar
DZeckhausen
It's not ceramic pads that cost $8,100 on the Porsche. It's carbon ceramic rotors. Your money gets you exotic rotors (and compatible pads) that are less than half the weight of conventional gray iron rotors.
Old Apr 25, 2008 | 11:51 PM
Marc V.'s Avatar
Marc V.
No squeal either. But is it true there is still brake dust, but just lighter in color so it doesn't look as bad? And if dust is left on wheels, will ruin wheels over time.
To Brake squeal gone.
