Cleartastic install
Old Apr 28, 2008 | 10:34 AM
383vett's Avatar
383vett
Default Cleartastic install
Brought home my 08 jsb Z06 last week, pulled the exhaust fuse and called Jeremy at Invisiguard for the full cleartastic install. He spent hours on the project and I ended up with a top notch result. I would recommend him to anyone in the SF Bay Area. He is a member of the forum and gives the members a very fair deal. Question to you all; is it necessary to buy the cags bypass or is it ok to simply unplug the connector. Does it result in a check engine light? Thanks, Willie
Old Apr 28, 2008 | 12:38 PM
Doing69's Avatar
Doing69
Unplugging to connector will cause the check engine light to go on. Go to Radio Shack and get a 220 ohm 1/4 watt resistor and connect that to the skip shift connector.
