Wheel question..........
Old May 6, 2008 | 11:41 PM
Andrew-NY's Avatar
Andrew-NY
Default Wheel question..........
Do you think 305s are too wide on a C6 without the wide rear fender kit? My fronts will be 255-35-19.
I just purchased Cray Manta wheels in 19/20 and I'm not sure if 295-30-20 would work better than 305-30-20s. I don't want to add the wide fender kit. I'm leaning toward the 305s because I want the Invos, but I don't want the tires to stick out too much.
My only option in a 295 is Toyo Proxes, which is all season ultra high performance. T1R not available in 295.
Any opinions? 295 or 305?
Old May 7, 2008 | 07:51 AM
NEV3R L8's Avatar
NEV3R L8
I'm not sure if 305s will fit with 20'' Mantas but on stock rims I've been told that they fit.
Old May 7, 2008 | 12:33 PM
Andrew-NY's Avatar
Andrew-NY
Why wouldnt they fit manatas? The wheel is 20-10.5" ? 315s would probably even fit on 10.5s, but it might look foolish w/o the rear fender kit which i don't want.
Old May 7, 2008 | 12:50 PM
jinkikim's Avatar
jinkikim
305 option will stick out about 0.5" with given off-set.
How about 245/35/19 & 285/30/20? (Toyo or Falken)
Old May 7, 2008 | 01:00 PM
NEV3R L8's Avatar
NEV3R L8
I'm sure they'll fit the rim but I thought you were asking if they would fit under the fender. On stock rims most people say 305's will fit in the rear on stock tires.
Old May 7, 2008 | 02:47 PM
Andrew-NY's Avatar
Andrew-NY
jinkikim,
Is that a problem if they stick out .5"?
Old May 7, 2008 | 04:24 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
If you get the offset right, you can put a 325 out back. I am replacing the stock wheels with CCW S500 (18x9.5 and 19x11) with 275's on the front and 325's on the rear with stock fenders.
Old May 7, 2008 | 05:37 PM
jinkikim's Avatar
jinkikim
Hi Andrew,
Someone including myself don't like stick out, at least flush with fender.
In addition, tires may hit the fender if you have a hard hit although the chance is slim.
I definitely do not recommend you 305 with Cray wheel offset (+65mm?), the maximum would be 295. 305 with 30 profile (20") is a little bit tall compared to stock. By the way, I don't see 295/30/20 tires in Toyo list, only 285/30/20
I do have Cray Scorpion wheels (18 & 19) with 255/40/18 and 295/35/19. Nearly flush with fender, but still 0.15" stick out at rear
jinkikim,
Old May 7, 2008 | 06:13 PM
SLICK SIX's Avatar
SLICK SIX
nope...just right
Old May 7, 2008 | 08:33 PM
C6 CYAA's Avatar
C6 CYAA
305/30/19 invos on 11" w/ 79mm offset. The outside lip stick out 13mm more than stock (even w/ fender) 10.5 w/ 56mm offset will be 20mm more than stock (about a 1/4" past the fender) I think it will be fine.
Old May 7, 2008 | 08:59 PM
keyplyr's Avatar
keyplyr
305/30-20 Toyo TR1s are flush w/ stock rear fenders.
Old May 7, 2008 | 09:54 PM
Andrew-NY's Avatar
Andrew-NY
Thank you!!
Old May 7, 2008 | 10:02 PM
NYC6's Avatar
NYC6
Why dont you ask the company you bought the wheels from?
Old May 7, 2008 | 10:11 PM
Andrew-NY's Avatar
Andrew-NY
Because they just want to push the 285s because they have a lot of them in stock.
I decided to go with the 295 30 20 in the Toyo. Toyo doesn't make the T1R in 295, so I had to go with the Toyo proxes UHP all season, which is supposed to be a good tire too. I hope I didn't make a mistake. The T1R comes in 305, but they were a lot more money.
To Wheel question..........
