Gas cap light problem
Old May 7, 2008 | 05:36 PM
Dons C6's Avatar
Dons C6
Default Gas cap light problem
Started up my 2005 Vet today and looked at the DIC and it said "Check Gas Cap". I cut it off, got back in and started it and it still said "Check gas cap". Drove it for about 25 miles or so, parked for awhile, got back in and it still said "Check Gas Cap". I drove it 10 more miles, cut it off for awhile, got out checked the gas cap, put it off and on 2 or 3 times, got back in, started it up and again when I started it up it said "Check Gas Cap". It did the same thing last summer and finally got alright. Does anybody have any suggestions?? Is there any recall? Or should I take it to the dealer?
Old May 7, 2008 | 05:41 PM
VET4LES's Avatar
VET4LES
I would get a new one from the dealer. It's an emissions warranty item.
Old May 7, 2008 | 06:29 PM
not08crmanymore's Avatar
not08crmanymore
Mine went 2 or 3 times when I had my 05.Less than a 3 minute fix under warranty at the dealer.
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The 2005 cars had some problems with the spring in the gas cap. I'd recommend that you head to the dealer and get yourself a new gas cap. If you are under warranty it is a 3 minute change. If not is about a $20.00 investment. If the cap does not seal properly it causes an error in the check of the pressurized fuel system. If it gets worse it can lead to a check engine light coming on. Just swap out the cap and be done with it.
Old May 7, 2008 | 07:47 PM
redline_ken's Avatar
redline_ken
This has been the only trouble code that I've gotten on my '05. A local dealer (where I didn't buy the car) took care of it in 20 minutes, under warranty. It took longer for the paperwork to be done.
Old May 7, 2008 | 07:58 PM
Arthur6's Avatar
Arthur6
On MANY (all?) newer cars if the gas cap is not tight enough it throws a code (like your getting).
If nothing is wrong other than the cap not being tight enough, it takes several ignition cycles (the car being started) for it to clear itself. It can be as many as 50 cycles, that would be about three weeks for me. MANY of my friends have had this happen, wifey fills the tank, doesn’t tighten the cap correctly - bingo... My wife has done this several times, she’s careful of breaking a nail!
My brother did this in his car, took it to the dealer, they used smoke (?) to look for a leak, bingo, loose gas cap. They did tighten the cap. Cost him $60.
Or I guess it could be a bad gas cap. I'm in a Corvette club, 200 cars, most are C6, have not herd of bad caps - yet.
Old May 7, 2008 | 08:03 PM
HummelS's Avatar
HummelS
Three clicks minimum when you tighten it!
Old May 7, 2008 | 08:23 PM
Ry05Vette's Avatar
Ry05Vette
I believe the owners manual says the code will stay on DIC until the cap is retightened and the car is parked overnight (so I'm assumming about 8 hours). Happenned to me and I found out the caps were bad on some of the '05. Like it was said earlier; just get a new cap and be done with it.
Old May 8, 2008 | 08:03 PM
Dons C6's Avatar
Dons C6
Thanks to all you guys for your input. Going to make an appt. tomorrow with my dealer.
Old May 10, 2008 | 11:15 AM
redline_ken
My cap was bad. It just kept spinning and wouldn't clip and stop. The dealer's diagnostic & fix consisted of: 1) Opening fuel door 2) Turning cap clockwise 3) Saying "Hmmm... it's defective" 4) Replacing cap and closing fuel door. I was worried that the motor might have to come out at first.
Old May 10, 2008 | 11:26 AM
Sven's Avatar
Sven
St. Jude Donor '08-'09
Old May 10, 2008 | 11:40 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I just had a problem a few weeks ago, when the gas cap wouldn't lock. It didn't show a code either. I replaced it myself fo $20.
Old May 10, 2008 | 12:08 PM
calemasters's Avatar
calemasters
Yes, there is an EI (Engineering Investigation) on this. Take it to your dealer and when they enter the VIN into VIS they will see the details. Basically, they just replace the fuel cap.
Old May 14, 2008 | 12:02 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
I have a 2005 C6. I just replaced the gas cap for the second time. Each replacement after about 20,000 miles on the car. After replacing the cap, it took four nights and about 20 start cycles before the "Check Gas Cap" message cleared from the DIC.
Old May 14, 2008 | 12:21 PM
cclive's Avatar
cclive
I may be missing something, but why would you get in and out three times and drive the car 35 miles before checking the cap as the DIC says...?
Old May 14, 2008 | 12:25 PM
greengo's Avatar
greengo
This may sound crazy but....three weeks ago my Vette said the same thing..
I tried everything for over a week and the message kept coming up....
IT STOPPED when
I filled it up at the gas station...hasn't come back on since??????????
Old May 14, 2008 | 05:15 PM
Wass's Avatar
Wass
I tried that too...Didn't work. You're lucky!
Old May 15, 2008 | 01:41 AM
DaveZeltser's Avatar
DaveZeltser
my 2005 is doing the EXACT same thing right now. I have tightened it like 10 times. It keeps coming loose. This is the second cap all of the sudden its going out again. I was noticing sometimes when i would pop it open to fill it that the cap was loose already but no message or code. Now all of the sudden the message wont go away. What gives?
Dave
Old May 15, 2008 | 09:11 PM
cherylandcliff's Avatar
cherylandcliff
Had to replace my cap on my 07 last week. Would not tighten. No problem with a light though. It was warrenty, but think it was about $12 if not.
Cliff
To Gas cap light problem
