Convertible Top Question
Old May 8, 2008 | 09:44 AM
luvlake's Avatar
luvlake
Default Convertible Top Question
Yesterday I was waxing my 08 Vert. It has a manual top, and I had put the top down to wax the car. After waxing, I went to put the top up and when I pushed on the hatch release button, it wouldn't open. I tried several times, no luck. Then I went to the opposite side to try that release, and again no luck. I started to get a bit concerned. Then I went back to the driver side again, and tried so more shaking the hatch. Finally it opened and the alarm when off. It always has been very tight when I close the hatch down covering the top. Does anyone else have a similar problem. Will the closing of the hatch get easier, more like a door, by using it more when putting the top down?
Old May 8, 2008 | 09:49 AM
johnodrake's Avatar
johnodrake
Moderator
Never had that issue. Where was your fob? Sounds like the car was locked. You can't (aren't supposed to be able to) open the tonneau with the car locked.
