How hard is it to install headers on a C6?
Is it hard like the old F-body Camaro's and Firebirds or is there a bit of room to get everything out and in easily?
St. Jude Donor '09-'10
I have installed both Kooks as well as American Racing. Both can be installed from start to finish in under 2 hours. This includes removing the complete factory exhaust. It will take longer if you do not have a lift. Playing floor ninja will add another 40 min or so. Hope this helps out.
Joe
Not too long at all, I installed Kooks 1 3/4's with the catted X-Pipe mostly by myself with the front end on Rhino ramps and the rear on stands in about 5 - 6 hours. The hardest part is getting the car in the air, while I was under there I replaced the wimpy tunnel plate with a 3/8 one from LAPD. I would have finished the job sooner but I thought the Flowmasters that were on it when I bought the car were welded to the H-pipe; I ended up cutting the H-pipe with a sawzall - not very much fun only to have it slide out...
JR
JR
I installed my Kooks, and it was my first experience installing headers. I am here to tell you that it was not hard at all. I will also tell you that it took way longer than 2-3 hours. It takes me that long just to get the car lifted, and the beer and music going. I am in no rush with those type of projects, so I do it in phases over a couple or three days.
Nothing really difficult, but I did do my research first. Only mistake was trying to unbolt the stock cats from the stock exhaust manifolds and snapping the bolts. This is common I later found out.
Enjoy the install. Have a beer and listen to old rock. It doesn't get any better than that!
Another thing he told me to do was to empty a couple of cans of brake clean on the new headers before firing up the car; he said the oils from our hands will burn into the headers pretty much permantly.
JR
Spray the h-pipe/cat flange bolts & O2 sensors with WD40 the night before.... drink beer. Net morning, unbolt the flanges, have an 8 inch stand under the body,to hold the midpipe when if falls. Replace with ARH headers, fit absolutely like GM inatLLED THEM
://specialty-auto-materials.net/
Forgot to add. Use stock GM head to header gaskets, also clean treads and reuse stock manifold to head bolts. This should resolve the headers bolts constantly coming loose.
Received 2,061 Likes
