Jump Start
I don't want to have my car towed to the dealer (last time I had it towed some skuffs showed up on the vehicle) to get the flash updates to prevent this from happening again, so I am trying to jump start the vehicle so that I can simply drive it a few blocks to the dealer. However, even when connected to another vehicle's battery and that vehicle is running for several minutes, the vette just wont fire up.
I spoke to what seeemed to be a helpful service advisor at the dealer today and he mentioned that after connecting the batteries together, get in the vette turn the iginition button OFF (i.e., hit it twice), exit the vehicle and take the keyfob away (out of sight) for at least 15 seconds. Then go back to the vette, get in with the keyfob and press the ignition button. He said it should start then, but nothing.
Batteries are connnected correctly, as all the lights are working, etc. When I hit the ignition button it just clicks but does nothing else.
Any ideas? Please help!
No problems with the stater....ever!
I discovered the dead battery in early April, I tried jumping it then with the same result that I had today. But, today I did the procedure that the service advisor mentioned and still nothing.
At one time, when I had the first DBS incident (didn't know at the time that this vehicle was prone to this problem) the dealer told me that I had to have the car towed in because the security system will lock up when the battery dies. After reading several threads yesterday after discovering this site I see no mention about this at all. That's what prompted my call to the dealer today to confirm what I had originally been told. He indicated that it may or may not be the case, but in my situation he did not think that the system went into a lock down.
If this is the original battery, you might consider replacing it ASAP! You might want to test the battery out first if possible and see if it is around 12 volts. If it is, I would be leaning more to the starter or something preventing power from getting to the starter (like a bad clutch pedal switch). Although in most cases like this it turns out to be the battery.
It is not the original battery. It was replaced in November 2006 just before the first DBS incident. I am convinced that this is a result of DBS as it's not the first incident and I just learned about this widespread problem last night on this site. So, do you think that I could convince the dealer to give me a battery without first having the car towed in? Or, do you think that it would be worth a try to remove the battery and see if it can be charged and then check to see if the car will start?
Last edited by VetteVickie; May 16, 2008 at 01:18 AM. Reason: Incorrect information entered originally
Can you advise as to how to test the battery while it's still in the vehicle stranded in my garage?
Because of repeated discharges, it sounds to me like the battery has a bad cell(s) - if it does, it will not hold a charge.
If your car is still under warranty, you might ask the dealer if you can remove the battery, take it to him and get it tested and replaced if necessary.
Make CERTAIN that all jumper cable connections are on GOOD. Wiggle the clamps around so they bite well.
Once the cables are on well, have the person in the running car rev their engine to about 2,000 rpm and hold it there... then try to crank you car WHILE their engine is revving at around 2,000 rpm. In my experience, doing this is pretty much necessary when jumping... not sure if you had been doing this or not... make sure you do.
If you still cannot start the car, see if you can get a battery from the dealer and drop it in the car, this way you can drive it over to the dealer, no flatbed needed.
Best of luck
And connecting a battery charger didn't make any difference. I knew the starter motor was good because I by-passed the starter relay and starter circuit by connecting a remote starter, and it would crank over and start. The solution was (and still is) to remove the battery from the vehicle, put the battery on trickle charge for 24-48 hours until it was absolutely, completely, fully charged; then re-install it into the vehicle. It seems the computer goes "brain dead" when the vehicle sits unstarted for a prolonged period.
Removing the battery then re-connecting it seems to kick-start the whole process.The permanent cure is to start the vehicle once a week and just let it idle for twenty minutes.
Best of luck
More good points. Everyone here is so very helpful!!!
I have thought about this. Connecting to either of the remote terminals, in my opinion, doesn't make for a good connection. It seems very flimsy. Should I try to go direct to the battery on the vette despite what the manual says?
Today I asked the service advisor at the dealership about reving up the vehicle that I am getting a jumb from. He stated that it was not necessary, that the vehicle need only be at idle speed. However, on my previous attempt to jump start the vette, I did rev the other vehicle quite considerably.
I will try to contact the dealer tomorrow to see if they will let me get a "good battery" to bring home. Good solution.
The cables are borrowed, and the jacket is not labeled with the wire guage. When I pull the handles down it looks as though there are only about 16 strands. Nice, thanks for getting me to look at them more closesly; on one of the ends it looks like there are several strands that are cut/broken. Maybe I will try again, with a different set of cables. I know someone at work who is sure to have the best of the best.
Thanks for your comments.
So, again I will see if either the dealer will give me a battery to drop into the vehicle so that I can drive it over to them, or I will tell them that I want to remove the battery and bring it to them for charging/testing.
Thanks!
Even when I spoke to the service advisor today about the widespread dead battery problem in this year, model, transmission type, he did not seem to be very familiary with the issue.
El cheapo jumper cables literally "feel" light---and they are in every department. Professional jumper cables are heavy, like a heavyweight garden hose.
And with all due respect to X, starting the car every week and letting it idle used to work and may still on late model cars. But not the newest Corvettes. It acts as more of a drain than a charge.
Literally, doing the "grocery run" type of driving (short trips, many starts and stops, couple miles or less of 30 mph or so) will wear down the battery and never fully charge it up. Eventually, it'll be dead. This I've been told from both Bowling Green tech and another, very knowledgeable source. So, be advised.
I know you're very recent to CF, but it'd help if you filled in some basic info in your profile after this is all resolved. Some on here might've been able to recommend a particular dealership as an alternative to the one your dealing with. Unless, your dealership is the ONLY one!
Good luck and come back and tell us how it all turns out.
Based on what I saw there is no way a jump start was going to start this car!
Anyway, I've got it on a tender for now and will replace the battery or have the dealer replace, which ever comes first.
