alignment
May 17, 2008 | 12:32 PM
alignment
I am looking to go get an alignment today, how much should i be looking to spend and what are the specs i should have them use for the alignment??
May 17, 2008 | 12:58 PM
to keep the front tires from wearing on the inside edges and getting noisy set the camber as close to zero (O) as possible
May 17, 2008 | 01:07 PM
i need them steup in a way where my tires wont pull to the side everytime there is not perfect pavement......
please give me all the specs i need so I can take it and have them do it
May 17, 2008 | 01:49 PM
May 17, 2008 | 02:13 PM
2015 C7 of the Year Finalist
Quote:
Originally Posted by
supervette26
ttt
please help!!
For mileage set the camber close to 0. I run camber at -0.10, toe and caster are set to spec which is found at the end of your search button.
As far as tracking issues on roads that have ruts? Fat chance. You have wide tires, They will do the dance on the ruts. Get used to it.
Elmer
May 17, 2008 | 02:25 PM
eboggs_jkvl
...As far as tracking issues on roads that have ruts? Fat chance. You have wide tires, They will do the dance on the ruts. Get used to it.
That's what I told him in
this thread, post #2 .
May 17, 2008 | 03:19 PM
St. Jude Donor '15
"In honor of jpee"
there are specs somewhere on this forum, I just can't find them. do a search above in red band for C6 Gen only.
May 17, 2008 | 07:25 PM
supervette26
try a little more toe in
May 17, 2008 | 08:40 PM
May 17, 2008 | 10:09 PM
