Display diagnostic/check engine codes
Old May 17, 2008 | 03:42 PM
hogasm's Avatar
hogasm
Default How To??? Display diagnostic/check engine codes
Is it possible to display the codes on 2008 c6 without buying interface.
I found the codes in the FAQ but I'm missing how to display them. Thought I read in the past but can't find. Pressing option or fuel multiple times or??????
Do I need OBDII can compliant interface to read? If So is there a recommended one?
Old May 17, 2008 | 04:02 PM
Vette_DD's Avatar
Vette_DD
No, you cannot display them on the C6 without a code reader/scanner. Others here will have to tell you which one you need.
Old May 17, 2008 | 04:23 PM
johnodrake's Avatar
johnodrake
Moderator
OBD-II CAN bus enabled will do it. Wally World, most Auto Parts and Amazon.com has them $60--$75.
Old May 17, 2008 | 04:53 PM
danl72's Avatar
danl72
Old May 17, 2008 | 04:55 PM
cclive's Avatar
cclive
Remember the CAN bus...thats the important part
Old May 17, 2008 | 08:35 PM
hogasm's Avatar
hogasm
So I need a OBDII Controlled area network compatible.... Brands any advantages there is quit a price range?
To Display diagnostic/check engine codes
