Remove A6 shift knob for console switch
Old May 22, 2008 | 12:40 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
Default Remove A6 shift **** for console switch
You guys really helped out with my last question so I'm hoping the is true with this one. I have a 2008 couple with auto trans. I'm going to replace the console. My question is do I have to remove the shift **** in order to do that?
Old May 22, 2008 | 12:45 AM
RadarP3C's Avatar
RadarP3C
You won't have to remove the A6 shifter. But, in order to clear the shifter, you will have to shift into neutral.
Old May 22, 2008 | 01:00 AM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
I have done it both ways. I think it's easier to do it taking the **** off, but then again I have taken my shift **** off about ten times and can do it in about 5 seconds. It can be done without taking it off.
Old May 22, 2008 | 07:01 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
As always thanks guys
Old May 22, 2008 | 07:30 AM
wayback's Avatar
wayback
Really easy. Twist bottom of shift **** (under boot) from 12 oclock to 1 oclock position. Pry up cap cover and remove, remove shift button. Pull straight up on ****. All there is to it.
Old May 22, 2008 | 08:52 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
Thanks, that does sound easy
To Remove A6 shift knob for console switch
