Need help ASAP
Old May 24, 2008 | 12:11 PM
Vetified's Avatar
Vetified
Default Need help ASAP
OK I just purchased a Borla Stinger exhaust system last week and it finally arrived yesterday. Well today when I got home I opened it up and this is what I found. Its still in the box and I need to know if this is normal. Please comment ASAP since I was planning the installation for tomorrow.
Notice all the rust along the welds as well as welds that look like a blind guy did them. Please look at www.borla.com and notice how nice and smooth the one in the brochure looks then look at my photos.
Thanks Guys for any and all responses. Let me know if Im being knit pickey here. Lot of oney to spend on something less than what I expected.
[IMG][/IMG]
Old May 24, 2008 | 12:17 PM
blackvetterzo6's Avatar
blackvetterzo6
I could be totally wrong here.But with welding, there is tremendous heat involved and thats the rusting color you are seeing.Just heat that was supplied to lay the bead.
Old May 24, 2008 | 12:20 PM
Vetified's Avatar
Vetified
That makes sence but the ones in the brochures do not look like this so now Im at a loss and do not know what to do. I just thought that the ones on the brochure would be what I was getting.
Old May 24, 2008 | 12:29 PM
chrisf9801's Avatar
chrisf9801
You will most definitely see some rust-like coloring on your exhaust. The pictures Borla puts up are probalby polished up after welding.
The only exhaust i've seen that was all shiney even after being on the car for a while was anything from Billy Boat.
I don't think you're being nitpicky, after all, you did just pay a premium for an exhaust for your pride and joy. Send it back if it makes YOU happy.
Old May 24, 2008 | 12:31 PM
Ozone's Avatar
Ozone
I don't think you're being nitpicky, after all, you did just pay a premium for an exhaust for your pride and joy. Send it back if it make YOU happy.
My only fear would be that the next set will show up looking the same or worse. But I do understand your concern. Good Luck!
Old May 24, 2008 | 12:41 PM
Vetified's Avatar
Vetified
So does anyone think that if I took some mothers and a pad and polished the H3LL out of the pipe would that illiminate some rust as well as make it shine a little more????
Old May 24, 2008 | 12:43 PM
XvettemanX's Avatar
XvettemanX
i put bassani on my vette and they had similar looking welds, no problems at all, i think all the previous posts have been spot on.
Old May 24, 2008 | 12:45 PM
XvettemanX's Avatar
XvettemanX
unfinished welded metal isn't meant to be pretty, just functional. I'm willing to guess the tips don't look like that.
Old May 24, 2008 | 12:49 PM
Vetified's Avatar
Vetified
OK Thank you to you all, you have seriously eased my mind. I do greatly appriciate all the post to bring to the conclusion that everything will be fine. I was truely about to blow a gasket if you all said the pipes looked like crap and I got the no lube treatment. I guess Ill keep the plans to install tomorrow. Ill post more pics when I am completed.
Once again thanks for all your help and info.
Jerry
Old May 24, 2008 | 01:03 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Welds are not that bad. (Seen lots worse) They will surface rust over. Like others said the company "tuned up" their product for picture taking.
To Need help ASAP
