Lloyd Cargo Mat
The top cargo mat corners for the convertible are cut at right angles and return in a straight line all the way down the sides to where they begin to curve around the rear of the wheel well.
The top cargo mat corners for the coupe are also cut at right angles but return in a straight line only a short distance (six inches?) down the sides where the begin to curve around the top of the wheel well.
Basically the top of the convertible cargo mat is a square all the way down to where it starts to curve around the bottom of the wheel wells; the coupe is not.
Many pics at mat vendors show the shape of the coupe cargo mat interchangably with the convertible cargo mat when they are selling the cargo mats. Here's a link showing a picture of the two different shapes:
http://www.westcoastcorvette.com/p-1...cargo-mat.aspx
Whether Lloyd has changed all that I do not know; but at one time that seems to be what they had for the C6.
I'm not absolutely positive, but I have had both and I don't think that power vs. manual top should make any difference. Good luck with it whatever it turns out to be.
