Error code P2138 again! Maybe fixed this time.
Old May 28, 2008 | 11:31 PM
tfkrato's Avatar
tfkrato
Default Error code P2138 again! Maybe fixed this time.
In January I posted I got a CEL and DIC messages SERVICE TRACTION SYSTEM and REDUCED ENGINE POWER. Turned out to be code P2138 and related to accelerator system. The problem disappeared the next day, the dealer could not find the issue.
Well, it happened again. All the same symptoms. This time the dealer had a memo (07-06-04-019) on the issue. Problem reported to be with a connector on the an engine harness (connector X184). Dealer found that there was in fact some corrosion. They cleaned it up, put on dielectric grease, and repositioned the connector.
Perhaps not coincidentally, it happened both times shortly after I washed the car. Although the hood is closed I do spray allot in and around the wheels, grill, and underneath the car. As the dealer said - it certainly is supposed to be waterproof.
Hope this is fixed for good!
Old May 29, 2008 | 12:49 AM
NEV3R L8's Avatar
NEV3R L8
Sounds like a mess but hopefully its all good.
Old May 29, 2008 | 12:59 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Glad they found it...this sort of intermittent problem can be a real PIA to diagnose. Sounds like you've got this one beat.
Old Feb 7, 2011 | 01:58 AM
jatolbert's Avatar
jatolbert
Is the problem still solved? Im having the same issue and I have tried everything!
Josh
To Error code P2138 again! Maybe fixed this time.
