07 with Paddle Shift
Old May 29, 2008 | 09:32 PM
John BX NY's Avatar
John BX NY
Default 07 with Paddle Shift
I have a 2007 with the paddle shift. When I shift I can see the gear change on the heads up display, but not on the drivers info center on the dash (just stays in D). Is this normal or should the dash light change as i shift also. Dealer says this is normal....I'm not so sure.
thanks in advance
john
Old May 29, 2008 | 09:41 PM
rlbock's Avatar
rlbock
Default paddle shift display
For what it's worth, mine is the same way, 07 vert.
Old May 29, 2008 | 09:42 PM
rdm1465's Avatar
rdm1465
Sounds right to me. '06 6A
Old May 29, 2008 | 09:43 PM
wayback's Avatar
wayback
Try different modes on the hud. It will always display on one or the other.
Old May 29, 2008 | 09:59 PM
RadarP3C's Avatar
RadarP3C
The only time I see the gear selection in my DIC is when the HUD is showing navigation directions. When the nav directions are no longer shown in the HUD, then the gear selection reverts back to the HUD. Also note that the only time the gear selection is shown in either the HUD or DIC is when the paddles have been selected in the "S" mode.
Old May 29, 2008 | 10:04 PM
jrpedraza's Avatar
jrpedraza
mine is the same way too, appears to be normal.
JR
Old May 29, 2008 | 10:05 PM
Swiftrider08's Avatar
Swiftrider08
Does "S" stand for Slow or Slushbox?!!!!!!!!!!!!!!!!
VETTE IV's Avatar
VETTE IV
I agree with RadarP3C, above.
Old May 29, 2008 | 10:17 PM
RadarP3C's Avatar
RadarP3C
Just wanted to pay the extra in order to help GM's bottom line.
Old May 29, 2008 | 10:46 PM
Vette_DD's Avatar
Vette_DD
Since A6s have 4 of the top ten spots, it stands for "Sport, don't miss your manual shift, or you've had it."
Showroom Stock
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 Z51 M6 - (2690)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6 - (337)
12.31 @ 114.82 - CYA Vett - 05 F55 M6 - (679)
12.35 @ 117.47 - Bain - 08 A6 2.73 npp - (2759)
12.40 @ 114.70 - Jschindler - 08 Z51 M6 NPP - (2138)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 117.11 - EZ28 - 08 Z51 M6 - (2735)
Old May 29, 2008 | 10:49 PM
candlemuse's Avatar
candlemuse
To 07 with Paddle Shift
