What buffer do you use?
But to get a real shine or to color sand and polish you must have a rotary buffer. I use a BD variable speed rotary when I need to actually buff something. Random orbitals are just just for removing waxes and glazes you really cannot do any real cutting or polishing with them.
The random orbit works much better on other types of paint, for instance my wife's Civic or my mom's VW Golf. In both of those cases I was able to remove imperfections quite easily with the UDM on the first pass, and without using anything super agressive either, I simply used a white LC polishing pad and Meguiar's #80.
Hib Halverson: "The Cyclo is a timeless piece of equipment which has changed little since it was introduced in 1953. Today, among its many high-profile users is the United States Air Force, specifically the 89th Air Lift Wing. Non-military types will know it better as the folks who fly and maintain Air Force One, the VC-25 (military version of the Boeing 747-200B) used by the President of the United States along with the aircraft used by the Vice President, the Secretary-of-State and the Air Force Chief of Staff. Needless to say, if you've ever seen Air Force One in-person, you've marveled at the aircraft's spotless appearance. How do they do that? Polishing with Cyclos. They have so many of them which are used constantly, that once every five years or so, the Air Force will ship pallets of them back to Cyclo Toolmakers for service. Cyclo "tunes them up" and ships them back to the USAF. There are Cyclos all over the world which have been in service 40 years or more.
The feature which makes a Cyclo unique is the overlapping, rotating motion of the two heads which mimics the two-handed, manual polishing/waxing technique old-school car care aficionados use when they hand-wax their cars. The Cyclo's buffing heads, which are run by a transmission geared to the device's electric motor, are dynamically balanced such that, when the unit is running and the heads are rotating, there is no vibration. The way this works is very similar to how balance shafts in large-displacement four-cylinder and V-6 engines damp vibration at idle and lower engine speeds. The Cyclo is built to last made of beefy alunimum castings, an HD electric motor and shafts riding on ball or roller-bearings."
http://www.corvetteactioncenter.com/...php?product=72
PC -- Porter Cable, a tried and true random orbital buffer. Will do some correction (ie. polishing) and help to keep a new finish new. Use a hook/loop pad or Edge adapter for dual sided pads. Most popular seller!
G110 -- Meguairs newest offering, this is a random orbital with a bit more horsepower under the hood. Think of the PC and UDM as its quite similar.
UDM --- we no longer offer the unit, it was an upgrade to the PC.
Cyclo -- this dual headed monster was all the rage a year ago. By using two smaller heads it can do alot of work easily in polishing your paint. Not speed adjustible and its only down fall.
Flex -- this new Orbital offering is the most popular currently. It has about twice the power of the PC. It is a safer choice versus moving to a true rotary buffer, and significantly cuts down on time needed for polishing. (cannot easily keep them in stock )
www.autogeek.net
stay away from those 10" and 13" inch big buffers sold on the cheap at Sears and Costgo amongst others. Often called the Waxmaster, they dont have enough speed or power for any real correction or polishing. These are wax removers only ...
also, the Vettes clearcoat is quite hard and using the newer Ceramiclear polishes from Menzerna and Wolfgang will help tremendously and speed work.
I'm able to remove 99.9% of the small swirls and scratches that end up on my all of my cars with the UDM. I have a wide assortment of compounds, polishes and pads and have zero issues with mine. I also have a Dewalt rotary with wool and foam pads for the really bad stuff but I've been able to sand scratches with 2000 grit and polish it to a great shine with the UDM. I just started using the Wolfgang polish and it is excellent stuff! (Thanks Autogeek)
Also, if anyone hasn't tried the Supreme Buff Microfiber from Autogeek they are freakin incredible. I just added about a dozen to my rediculous collection of microfiber. Adam's used to make my favorite microfiber but now its too close to call.
Me too.
