Erradic Voltage
Old Jun 2, 2008 | 07:38 PM
rmarks's Avatar
rmarks
My 2 cents.
Remember you are measuring BATTERY voltage. And this should not vary so much unless:
A) the battery is bad
B) there is high resistance in a connection from the battery.
So - check that the battery connections are tight, not corroded, etc. If they look good, get out your volt meter. Put it right on the battery - not on a connector, but get in there and make sure the voltmeter probes are actually touching the battery. Then see if the meter in the car reads / fluctuates the same as the voltmeter. If it does, I don't know the problem, but guess bad battery. If it doesn't, then keep moving the voltmeter probes back along the main power cables until you see where the voltage is varying. The point of change is the problem. If you live in San Diego call me 858-243-2736 and I'll help.
Old Jun 2, 2008 | 07:56 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Old Jun 3, 2008 | 12:33 AM
cclive's Avatar
cclive
Originally Posted by rmarks
My 2 cents.
Respectfully disagree....if the engine is running, then you are measuring the SYSTEM voltage, which should be pushed up to 13.8-14.4 by the alternator. If the engine is off, then you are measuring the battery voltage because there is no contribution from the alternator. The system voltage is actually pulled DOWN by the battery when the engine is running. Its not a good thing to do, but if you disconnect the battery while the engine is running, the system voltage will go up.
Old Jun 3, 2008 | 05:41 AM
bolivar's Avatar
bolivar
My guesses are:
1) Battery is bad, going to get worse. You could just do nothing and the battery will totally fail sometime soon.
2) Bad cable connections. The voltage in our Cadillac bounced around (from about 11.9 to 15.3 volts) the entire 1,500 mile trip to south Florida. I pulled the rear seat to get to the battery and tightened the ground and all other connections back there - the variations in voltage stopped.
Old Jun 3, 2008 | 06:58 AM
Mad*Max's Avatar
Mad*Max
You are going to need a new alternator soon.
Old Jun 3, 2008 | 09:58 AM
05_C6_cja's Avatar
05_C6_cja
Thanks again for all your feedback guys. Truly in you all's debt.
I haven't gotten any service charging system messages. My baby has 26,159 miles on her.
I ended up pulling the alternator yesterday and tried getting it bench tested but the local auto zone, advance auto parts, and o'reilly didn't have the connectors to test it.
My dad went to drop it off today with a buddy of his who repairs alternators. He is going to check it out for me and repair if necessary.
I will definitely keep you all posted on the results.
Old Jun 3, 2008 | 04:28 PM
05_C6_cja's Avatar
05_C6_cja
Ok so the results are in. For those of you who guessed alternator...you are correct. Regulator and diodes need replacing. Price for repair $120.
I sincerely thank all of you for your help. This is an awesome site.
Old Jun 3, 2008 | 05:44 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Yay!!
Old Jun 3, 2008 | 06:00 PM
VET4LES's Avatar
VET4LES
Good news. Let us know the voltage reading's when you get it back together.
Old Jun 3, 2008 | 06:26 PM
Mad*Max's Avatar
Mad*Max
This was typical behaviour of GM alternators and I've owned a few GM vehicles so it wasn't difficult to assess.
Old Jun 3, 2008 | 06:49 PM
F40's Avatar
F40
Old Jun 3, 2008 | 07:39 PM
cclive's Avatar
cclive
Glad it turned out OK...but maybe "guess" isn't quite the right characterization. From the symptoms, some here thought that the alternator was the logical place to go...
Old Jun 3, 2008 | 08:01 PM
  #33
TXSTICK's Avatar
TXSTICK
If I were you I would still get a load check done on the battery. On my 04 I had taken it to the dealer for the volatage fluctuation and they said it was fine, on week later I went to start the car and it was dead. They put in on a truck and took it to the dealer. The battery had a bad cell and took out the alternator. They had to replace both.
The 05 was rock steady just above 14 volts and then started with the fluctuation. Finally the battery was dead one morning (18000 miles on the car) and I jumped it and took it to the dealer. They replaced the battery
(bad cell) and now it is rock steady again and it has been 3 months.
So it would not hurt to have a load check done.
Old Jun 3, 2008 | 08:35 PM
  #34
LMBC6Brian's Avatar
LMBC6Brian
I've been having some funny voltage readings on my 05 for the past week. The voltage has been fluctuating anywhere from 11.8 - 14.3 within the same drive. I've noticed that in the afternoons (3pm - 5pm) the voltage seems to drop more and be unstable as compared to the mornings and evenings when it's cooler outside. I'm not sure if this even has anything to do with it or not...just an observation. I was hoping you all could help me out with any advice or expertise. I appreciate it.
My 07 C6 has been doing this from day one. My car did it when it was stock and still does it with the vortech installed. I also have NO DBS issues so far.
Brian
Old Jun 3, 2008 | 10:06 PM
  #35
05_C6_cja's Avatar
05_C6_cja
I apologize...didn't mean to offend anyone.
Let me try again..."for those of you who diagnosed the problem as being the alternator..."
Thanks for the heads up. I'll make sure to get this done tomorrow before I install the alternator.
I sure will.
Old Jun 4, 2008 | 12:28 PM
  #36
cclive's Avatar
cclive
If the battery is the original one, then it could be up to four years old...it will definitely not pass a load test as a new one would. Any electrical system in a car should be able to maintain 13.8 to 14.5 volts under any reasonable load, including high current accessories like window defrosters or heated seats. If the voltage while running is fluctuating more than a few tenths of a volt, then there is a problem that should be fixed. Lower voltage will damage a battery if continued for a long time. All voltage regulators have a voltage that they will maintain and it can be a bit different for each one due to manufacturing tolerances, but once you know what that voltage is, it shouldn't fluctuate much or something is wrong. All this applies when the engine is running at speed, at idle sometimes the alt is not being spun fast enough to keep up, but at 80mph on the highway, more than a few tenths of a volt is not acceptable.
Old Jun 4, 2008 | 03:02 PM
  #37
05_C6_cja's Avatar
05_C6_cja
Thanks for the input CC.
Battery is an optima red top. I believe it's around 2 yrs old.
