Power Vert Top Partial Failure
Old Jun 2, 2008 | 08:20 PM
emaxwell's Avatar
emaxwell
Default Power Vert Top Partial Failure
I have an '05 power top w/ 10k miles on the car. Went to lower the top the other day. At about the 1/2 way point, the tonneau cover falls back down against the glass and the top jambs. I can release the hydraulics and move the top manually, but that's not what I want to do. Just two weeks out of warranty. Any help would be appreciated.
Old Jun 2, 2008 | 08:25 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Originally Posted by emaxwell
I have an '05 power top w/ 10k miles on the car. Went to lower the top the other day. At about the 1/2 way point, the tonneau cover falls back down against the glass and the top jambs. I can release the hydraulics and move the top manually, but that's not what I want to do. Just two weeks out of warranty. Any help would be appreaciated.
Old Jun 2, 2008 | 08:56 PM
gsport's Avatar
gsport
take it in quick..... i've taken cars in just past warranty and they went ahead and took care of it anyway... good luck
Old Jun 2, 2008 | 09:18 PM
svoshop's Avatar
svoshop
I agree. If you have a good relationship with your dealer, I would assume they will help you out.
Mike
Old Jun 2, 2008 | 10:55 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I have also taken cars in after the warranty has expired and the dealer has come to bat. If you don't get satisfaction set up a claim through the GM hot line and insist the GM area service person get involved.
I had a Camero lose the right power window and water pump at the same time at around 48,000 miles and GM agreed to do the repair at half price.
Got the clutch replaced on my C5 at 55,000 miles when I proved it was defective, unfortunately they only covered the parts and the labor was around $1,600.00.
I use the logic that I purchased the car under the assumption the quality would allow the parts to last longer.
Old Jun 3, 2008 | 12:54 AM
cclive's Avatar
cclive
Only two weeks out, they will probably be good and cover it...go in soon and smile alot!
Old Jun 3, 2008 | 03:20 PM
emaxwell's Avatar
emaxwell
They have it right now. It seems there is an optical sensor that tells the car where the tonneau cover is. This sensor appears to have failed. They are trying to do this under warranty.
Old Jun 3, 2008 | 08:11 PM
emaxwell's Avatar
emaxwell
Henderson Chevrolet is my hero. They fixed it and got me back on the road. If you are in the area, see "Ray-the bald guy"
To Power Vert Top Partial Failure
